I have been wanting to do a compression test for a while now, but i don't know where to get the tester itself? Would my local parts store have one?
they might i got mine from an harbor freight store mosty stores that carry automotive tools will have them
I should check go there and check. Thanks for reminding me.Quote:
Originally Posted by 87lxiaccord
yeah, harbor freight can hook you up. they practically give tools away there. or if they're not in the area, they sell them at wal-mart too. or ebay if all else fails. http://www.harborfreight.com/cpi/cta...emnumber=39224
May even be able to rent it form one of the auto parts places. I think advance still does tool rental.Quote:
I've seen a compression tester at O'Reillys for about $20, which comes with two fittings & fits most spark plug hole applications.
Yea i have seen that today. They had a $15 one a $20 as you mentioned and a $42 one. So the $20 one should be good?Quote:
Originally Posted by ddude2uc
Whats a good pressure reading on a compression test
Just take a spark plug out & go up there to make sure you get the right one by matching the diameter & pitch of the threads. No need to get a high dollar one.Quote:
Preferably around 178 psi (which is max) & no lower than 135 (lowest)..Quote:
Originally Posted by picopop
With the highest & lowest readings no more between 15-20 psi..
