Originally Posted by w261w261
Yikes, the tape...so ghetto, and ugly too.
Your problem, assuming the leak is on the driver's side, is that the sunroof LF drain goes down to a Y connection by the antenna motor. The drain from the motor goes into the other part of the Y. It's most likely unplugged, and also the end of the drain in the front wheel well is plugged. Water comes down the tube, backs up because the end is plugged, and comes out at the Y. You can fix it good enough by clearing the end of the tube in the wheel well. It is a little tricky, more so than the back drains.
