Re: my heater stoped working
if yu pull out the tray in front of the fuse look on the back and it should give you a good idea. The other thing s just start pulling them one at a time and checking.
My heater doesn't work in my 3gee, and im pretty sure there is no fuse for it... I just looked...
We need more information to answer this. The "heater" itself does not have a fuse, but the blower motor does and it also has a relay. Does the cabin fan work? Does the car get up to operating temp? How long does it take to get up to temp? Is the carpet wet at all?
Well I can hear the fans blowing, but there is just barely any warm air coming out of the floor vents. None through the dash vents, and barely any through the defroster vents. Its luke warm air, not nice hot air like its supposed to be. I know the thermostat works because the car gets up to temp, and the guage does work. My car warms up in about 5 minutes.
well MINE blows pleanty of cold ass air but no warm air at all mine also warms up in about 5 minuets
check if you cable is not lose....have a buddy check your engine bay...the cable should move and and out...comes out of the firewall
Sorry if it seemed like I jacked your thread, I didn't mean it like that, I just thought maybe both of us with similar problems could both get some help in the same thread, so I don't have to make a different thread for the same thing. :)
what cable are you talking about messy?
its passes the firewall and it moves the valve...depending on how much you move it the more hot coolent will travel thru the heater core making the heater hoter or colder.
What was not working such that you replaced your combo switch? If it was getting good and hot before, and is not hot now (not counting the slow air flow), I'd say that the slider that controls the cable to the heater valve (in the engine compartment right by the firewall - have to take some stuff out to get to it) is not hooked up right. Does the fan have multiple speeds that you can hear, even if there isn't any flow to speak of?
the combo switch is the switch that controls the blinkers/wipers
