Re: Many questions re B20A
After a bit of searching it seems the B20A and B18A gearboxes are interchangable, but are they the same?
The gear ratios are most likely different but that shouldnt stop you from using one of those if you cant find anything else. The B18A trannys are pretty much unknown territory. I think their serials are B2N5
Goldtop and Blacktop should share the same tranny bolt pattern. It should work.
wohdog has a b18 gearbox on his car i think, also this thread helps a billion :) https://www.3geez.com/forum/showthread.php?t=11809
I'm sure the gearing won't be that different too. It may just be something with the casing or internal construction.
The B18A tranny will bolt to the B20A too.
I posted the B18A gear ratios somwhere.
cool get a 88-89 parts car...so you can sell off the parts here while you get a 5 speed swap.
