Would the intake from an a20a1 fit an a18a1, or do I need to modified anything? The car is already fuel injected thats where the a20 is coming out
of. I just need to drive around till I get the a20 fixed.
I would think that it should work fine. What kind of car are you doing this to?
IIRC the manifold won't even be close, round ports on the a18 vs oval for the a20. You may be able to use an ES3 manifold from an 85 SE-i but those are very hard to find and I'm not sure if it will line up anyway. I can't see any sense in getting a custom manifold made if this is going to be temporary engine. IMO you'd be better off getting an a20 from a junkyard to hold you over.
andy
