Fuel Pump??
Hey guys,
Got another problem...I replaced my motor cause it was leaking oil badly and it had so many problems, and as many of you know last year i did a carb to efi conversion. Now....I drove home yesterday fine, but once I went out at night i was driving, take of shift from 1st to 2nd the engine light came on but went off once i shifted into second. I kept on driving but then teh motor just shut off while going 60km/h. Now it wont start...I think its either the furl pump cause i dont hear it turning on when i put on the ignition but i ran wires manually to the pump and it turned on from the battery. So I think its the mitsuba relay RZ-0028 cause i already checked the fuses and such. Anyone got any ideas? Thanks!
Re: Fuel Pump??
if the engine light came on...check the ECU code.
Re: Fuel Pump??
well it came on for a split second. I tried another fuel pump that i know works and it didnt work, I even tried another relay and that didnt work. I'll check the ECU codes, but if anyone else knows any other relay that would cause this let me know!
Thanks
Re: Fuel Pump??
okay well I just check the computer and the LED isnt lighting up at all. I got another computer lying around, so I'll switch it out, but do you know what would cause it to go? Thanks Messy!
Re: Fuel Pump??
Did you check your distributor, rotor,cap, plug wires, coil, spark plug wires? When was the last time the fuel filter was replaced?
Re: Fuel Pump??
Yea, I checked the electrical system and the engine is getting spark and I ran power to the manually from teh battery to the fuel pump and it turned on. So I know the fuel pump is good. I'll try the ecu but im curious as to what caused it to stop working? And the fuel filter was replaced last summer.
Re: Fuel Pump??
The honda is back, turns out I forgot one of the grounds was loose. Tightened it and it runs like a dream! Thanks for your help guys! Next is time for alignment and intake! I'll post pics when im done!
