ok someone said i come get the part off this 4gen accord be4 it goes to the jy so what all can i get off besides map sensor? need info in a hurry not trying to rush or enything.
map sensor, rims, seats if there better then yours
X2 and stering wheel
4th gen wheels dont fit 3geez unless they are multi fit or either car has fucked up hubs, i think
performance parts...
trottle body, injectors, dizzy with wires for OBD1 swap. computer if you can. map sensor, and take the fuses out...for spares
rims dont fit our car....plus they UGLY.
Spoiler if so equipped, speakers if aftermarket, maybe the shift knob if you like it. Grab the wheels if they're aluminum. Scrap cast aluminum is over $1.50 a pound. If you cut off the old tires and scrap the wheels, you're looking at a good $50-$75 bucks.
^ :orly: are the stock lxi wheels aluminum?
Originally Posted by frantik
im not sure but i think they are alloy....
thanx i will take that into consideration i thought the seats didn't fit and obd1 what all i need to take for the conversion
yes, for sedans, at least.
what year is this accord? 92+ is obd-1 and you'll need dizzy, ecu, a whole bunch of sensors, and lots of patience. and there's other stuff that i'm forgetting atm. i think igniter and other similar components.
Yea the 4gen is a 4x114mm bolt pattern if i am correct.Quote:
Originally Posted by A18A
all 4th gens are obd1Quote:
Originally Posted by snoopyloopy
so if he decides to take the plunge he'll need the ecu, dist, o2 sensor, wiring harness for the dist/ecu /o2, and pull all the sensors. the accord ecu wont be that great though.
Originally Posted by guaynabo89
yeah but the 92-93 have the external coil...so that means you can run an MSD coil. the early ones had the enternal ones that would heat up and cause them to last like 30k.
oh, i was under the impression that no hondas were obd-1 until 1992-1995 then afterwards obd-ii and it's variants.Quote:
well sounds like to much trouble i went 2day and got map sensor, speaker they were pionerr premiers so i got them and the radio which wires go to which on the map sensor.
sway bars!
some kid prolly told you this since the obd 1 civics were from 92-95,Quote:
in 96- some government action made every car company convert their cars to obd-2. and i think all cars made previous to 96 that are efi are obd-1 with honda/acura.
