Re: 88' Repair Headlights
Both headlights won't go down? did you check he fuses? It is no. 7 in the fuse box under the hood.
Yes sir I replaced the fuses and I was reading this same issue with this topic: https://www.3geez.com/forum/showthrea...ght=headlights
However, the problem with me is I don't have another switch. I can manually put both lights down and when i turn them on or press the button they stay retracted.
Any thoughts?
P.S. When I get these to work I'm gonna have to fix some body work... the left headlight is hitting the front bumper.
Replace the retractor switch. It's been a problem many of us have encountered in the past.
ya the switch could be a problem, if you guys want to do a controlled test disconnect the retractor switch and you'll see that once you open the lights they wont close again if its disconnected. If you don't know the retractor switch is the button on your dash to get the headlights to open when you want without turning on the lights.
if you need the motors, i may be able to get you some
