Rear window trim removal??
Can someone explain how to remove the rear window molding? I see there are a few screws at the bottom of the window to remove the lower part of the molding, is the rest snapped in place? And if it is snaps do they brake easily should I even attempt to remove and repaint or just tape it all off?
Re: Rear window trim removal??
take the screws out, and very carefully pull it left (on the drivers side, right on the pass) it is on there with brittle tabs, but if you do it carefully you can avoid breaking them.
