Please Help! Gas Gauge Read Full!! ???
I changed the instrument cluster and my gas gauge is reading full?? It wasn't doing this at first. It worked normally, but now it's decided to do this.. What's going on?? Did I do something? How do I make it work again? I've tried searching. And spent ten minutes looking through this. I don't want to be up all night so if you already know the answer I'd greatly appreciate your response.. Thank you guys!
Re: Please Help! Gas Gauge Read Full!! ???
Twice I tried swapping my auto cluster with one from a 5 speed. The first one was a Denso, the second was the NS. Both read on F all the time. I just swapped the auto fuel and temp gauge into the NS. The gauges will not interchange between the NS and Denso.
That's my problem! One's NS, and one's denso... Damn it.. I know what the problem is. The copper thread is disconnected behind the needle on the other side of the gauge... and it's next to impossible to fix..
LX-incredible
How do you take the needles off the gauges?? If I could get them off I could take the damn thing apart and fix that pain in the ass wire.. Do I sound irritated? lol. I am but, only because this is annoying me. Anyone know how to remove them? Pulling isn't working.
I has the same results with both the NS and the Denso 5 speed gauges. The only way that I could get it to work was to use the auto temp/fuel gauge. It must just be common for these to go, I can't see them being wired differently for auto. You can swap the Denso and NS clusters, but you can't swap the individual gauges. The sizing is a little different and the connections are different.
800
just drive around for a while it'll go down :kekeke:
Lol, that's the best sound advice I never heard.
frantik
The fuel light should still work right, even if the gauge has decided to be hormonal?
The guages are not interchangeable but the little car indicator that tell you which doors are open, which lights are burn out, and in some cases which gear your in (automatic).. that is interchangeable.. It makes it nice if your swapping a gauge cluster from a two door to a four door..
LX-incredible
800
Well I connected it, hopefully the fuel gauge works and I didn't mess up the temperature gauge. If I did, does anybody have a NS fuel and temperature gauge for a manual??
Man i gave out the idea that the fuel and heat guage may not work and i was right. Now you should do a how to just in case people need to do this.
These gauges do work but I messed them up! on the NS gauges there is a thin copper wire that wraps around in a ball several several times.. Well I needed to removed the guages to put my 4 door is ajar, brake light and headlight out indicator; because the gauge was for a two door. Well when I went to put the gauges back on there are screws that connect a soft circuit panel to the gauges which in turn meet up with that copper wire mess. Well I overtightened and broke the copper wire so the gauges stopped working. And the only way to get to the copper wire to try and fix it is to pop the gauge face off, in turn removing the needles. When you remove the needles if you spin the motors at all or don't put the needles on relatively close to the way they were before (like setting the timing on your ignition) then it will read incorrectly; or possibly not at all.. So don't ever mess with these needles, they are a pain in the @$$. If anything my theory once I get another replacement gas and temp gauge is that the gas gauge will goto the full mark when I fill it, but not go back down... I could be wrong, and hopefully I am.
russiankid
blh1983
That must have been what happened to me, I do remember some of the screws feeling like they were starting to strip. I accidentally moved the needles on the auto fuel/temp when installing, but checked that they would move equally into the extremes. As long as they are moved slowly, the needles won't lose place. I'm going to check the other 2 fuel/temp gauges for broken wires.
PROBLEM FIXED! I went to pick a part took the gas gauge, fuel temp and door and light indicator from another 3G with a NS cluster. And they just gave it to me for free! I installed it and turned the screw by hand, just so they were hand tight and my gauge cluster is now working perfectly.
