roodoo2
:huh:
If you have that much compression loss, valve seals ain't gonna fix that blow by problem
Power surge? are you talking about loss of air pressure?
certainly the quickest way to get it done, using air, carefull you dont damage your threads though
the rope will get it done but pay close attention to what you are doing, also do not turn the motor with the starter, do not turn the motor backwards if you can help it.
If it becomes a big deal, look at the time you are going be using.. sometimes it may be better to just remove the head and freshen it all up anyway.. lap the valves, check the guides, new T-belt, clean out the carbon, inspect your cylinders, port and polish the head (that could take a couple of days) and take it to machine shop to resurface and wash.
