Re: stalling out at a stop
Oh yeah, and also have recent plugs, wires, cap, rotor , tw sensor, fuel filter by firewall, and injectors too. There is no CEL but the ECU is throwing code 1(primary oxygen sensor) which is on it's way to me as we speak. I don't see how that could be the culprit as I saw this code before tonight.
If its cranking I would look and see if you have spark. The tach needle jumpng around usually means the distributor going bad but since its new it is possible that your tach has gone bad.
is the rpm going down to low??
I think it was down low, btw, no injector click now.
Jump the main relay out there. a couple write ups here about it in the EFI section. Just do it as a test to see if its cutting the fuel or spark off.
Yeah, it was the Main Relay. I just didn't think the relay would cause it to not start at all even after enough time and in the cold.
