Re: 89 se-i need some input
Is there smoke coming out of the exhaust? Is the oil black or a chocolate milk color? Check the anti-freeze and make sure its green. If indeed the headgasket is in need of replace, wont be to much if you do the job yourself, but the head would need to get checked for cracks and if it is warped. If a shop does it, it may be a bit. The water pump is easy to do as well.
for $500 who cares if it needs some work
specialy if its an sei with 5spd
Hauntd ca3
werd...offer him 400 bucks and take the car off his hands...if you are good even a head gasket would not be too hard.
Alright thanks guys I'm going to pick it up today, I'll post pics later...........Thanks all
Alright guys so I picked it up today, $300 yes three hundred dollars. I got a new valve cover gasket and replaced that, that took care of the smoking part. I also went to the local parts store to get some of the antifreeze additive to stop leaks and that is what is coming from the bottom which leads me to believe someone tried this before. I am definitely thinking it is the water pump now, there is nothing in the oil no loss of power (drove 50 miles home). I did think the heat should blow a little hotter, if the water pump is bad will it affect the heating??? I promise I'll post pics tomorrow, I think it looks great and everything else seems fine, needs a few little things like brakes, rotors, wiper blades etc.
If the coolant is leaking it can effect the heat, since it's run by coolant
forrest89sei
If the fins on the water pump are gone from corrosion there won't be good heat either.
Any SEi for 300 bones is a steal! Post some pics and cooling prob fixed :cheers:
as long as it had anti freeze in it, even if it was the head. Hell YEAH!
Damn, sounds like you got a steal of a deal. So far it seems a bit mixed weather or not you have a blown head gasket, leaning a bit more toward it not being blown. Post some pics when u get the chance ^^
Alright guys here are a few pics..............$300 for car, $130 for title and tags, $20 for valve cover gasket, $20 for oil antifreeze and coolant leak sealer. Seems to have stopped leaking and runs great, thanks for the help and comments guys.
http://i52.photobucket.com/albums/g3...e/DSC01855.jpg
http://i52.photobucket.com/albums/g3...e/DSC01856.jpg
http://i52.photobucket.com/albums/g3...e/DSC01857.jpg
http://i52.photobucket.com/albums/g3...e/DSC01858.jpg
Not bad at all. Where in PA are you? Also your power steering fluid is low, actually below minimum. Make sure to use Honda.
Looks like a clean sei other than the poor seats!
That SE-i Looks Pretty Damn Clean :D :thumbup:
And :jawdrop: on that Civic VX mileage, I didn't know it was that high!
Im in Reading, PA. Thanks for all the nice comments guys. The Civic gets crazy gas mileage and it's only a 10 gallon tank so $20 and you're good for the week unlike the Z $20 where gets you only one hellrun......lol
imjdoggie
I'm moving to either Oxford or somewhere around Chester. We should have a mini-meet:wave:
