Rear crankshaft seal and clutch advice
I think it's about time for me to replace my rear main seal. The leak is bad enough that my engine compartment is a real mess and I need to add oil a couple times between changes (it's lower than I like it, not below the 'low' line). I've been through the old posts and still had some questions. Why does the spring in the new seal need to be shortened sometimes? Should I just go ahead and shorten mine to be sure I don't have to redo the job?
For those of you that have already done this job, do you have any advice for me? Is there anything you wish someone told you before you started? How much time should I expect to spend? My clutch seems to be ok, but it has 74k on it now (only 25k of mine, so I have no idea about prior abuse). Should I plan on replacing it, or take a look at it first? If replacement is a good idea, what would you recommend as a durable, inexpensive clutch (stock grab is fine)? I use this car to get around town/to work and I don't have a good place to work so I'm trying to be able to get this done quickly--well quick for a big job anyway.
My transmission fill bolt is frozen in the housing so I should be able to finally get that thing out and change/fill my tranny oil...so that's good I guess...becuase you know I really wanted to have to drop out my transmission:rolleyes:
