battery relocation wire routing
well, as luck may have it, ive installed the battery box on the drivers side of the car, and its firmly bolted down there. anyways, the original wire ran through the drivers side and out a hole behind the pedals. since i have relocated my fusebox to the passenger footwell, i must relocate that entire power wire as well. what would be the cleanest way to do this?
Re: battery relocation wire routing
Cleanest way to do what?
You already have the battery box mounted, and also the fuse box.
The cleanest way to run wires are to go under the carpet, but if you don't have carpet, then split loom(Conduit) and zip-tie it.
Edit: I don't think I can answer this question the right way.
