We all know what what white smoke means out of the exhaust i should not have used that cheap ass Federal Mogul gaskey kit i should have used AJUSA gasket kit but whats done is done. i keep you guys updated.
That sucks!!
yuck. My BG Automotive gasket held up fine so far. I had to retorque it after a couple of days tough. Painful thing to do but it was worth it in the end.
gay. i know how it feels.
you should of stucked with the a20
i like how you never give up
Stud the block if you are going to be merciless on the old girl.
Sorry it is broke already
I have APR head stud but i went cheap on the head gasket + kit now i am paying for it.
http://memimage.cardomain.com/member...7_255_full.jpg
you're not talking about stock cylinder pressures are you? it should hold up reasonably well stock, right?
Update
i got it apart and the head gasket was goodhttps://www.3geez.com/forum/images/smilies/dunno.gifi was like https://www.3geez.com/forum/images/smilies/wtf.gif so i took the head to the machine shop and had them check it out pressure tested and pull the head apart and check for cracks and nadahttps://www.3geez.com/forum/images/smilies/dunno.gifso i started to take a look at my ebay turbo and it was leaking on the hot sidehttps://www.3geez.com/forum/images/smilies/badpc.gif the bearing are shothttps://www.3geez.com/forum/images/sm...ocketwhore.gif so i went out to PnP and got another garrett Center Bearing Housing off a T Bird and fixed my ebay turbo. All that shit and it was not the head gasket at least i got a valve job now time to start to put back together.
You scared me because i have that head set and might use it unless i find a better alternative soon. It looks decent but not as high quality as the OEM honda ones looked so i was skeptical of using it.
Good luck this time around!
good to hear your motor is good. its a good time to use a better turbo. so what a PITA, but it sounds like the setup is going to be better now!
Here some pic's
Egay Center Bearing
http://i109.photobucket.com/albums/n...d/DSCN7214.jpg
http://i109.photobucket.com/albums/n...d/DSCN7215.jpg
http://i109.photobucket.com/albums/n...d/DSCN7217.jpg
http://i109.photobucket.com/albums/n...d/DSCN7218.jpg
http://i109.photobucket.com/albums/n...d/DSCN7211.jpg
http://i109.photobucket.com/albums/n...d/DSCN7213.jpg
