there seems to be no fuse i can find for this...it has to be a fuse..it doesnt turn illumination on and the headlight beeping has stopped also...help!!
basically this means i can drive at night but ill have no idea how fast im going....common guys..somebody's gotta know somthing
check the dimmer
Where?...liek where is this thing i should look for..and whats it look like?..there is no dimmer fuse
21 views and no other replys ...somebody has to have had problems like this in the past...how do i check the dimmer..i gotta get this fixed...
did you check all your fuses under your hood too?
The dimmer is the little roller thing next to the switch that makes your lights popup without turning them on. It adjusts the brightness of the interior illumination.
it should be a 15 volt fuse blue next to your spare ones it is not labled for the dash. Under the dash bord.
okay ur gonna have to be a whole lot more specific
...i looked for what u said..next to where?..what number slot?
i need a diagram or something if u know where it is u should be able to tell me where
hey micah, its u again. :) that is really weird man. your guage all of a sudden went black. how is the dimmer switch? did u roll it up and down. that sounds cheesy. is any of the lights in your console like the heater control and the fan switch light up too or are they out too? this is the first every problem we have heard of. did it happen all of a sudden or after the accident and happen after u started to fix it?
happened yesterday man as far as i know...and it worked when i got my headlights workin..it juts decided not to..nothing on the dash lights up..and headlight indiactors dont beep anymore
*indicators..haha indactors
OK ajust your seat all the way back and then tilt it all the way down lay on the seat with your feet at the top. look under all the stearing wheel stuff and above the brake pedal area there should be a fuse box for me it was the number 14 fuse a blue 15volt or amp take a look good luck
yup it was fuse 14 but only prob is something is pulling too much power and fuse 14 blows everytime i turn my lights on...so now not only do i have no dash i have no license plate lights or tail lights..which means still no night driving...guh..i dont know whats wrong..what could be pulling power..i havent done any mods in quite a while
my friend suggested maybe i got some water in one of the lights and thats why its shorting out...would make sense considering all this rain...ill check that tommorow...gotta be either the right tail or the license plate lights
Try the brightness control amplifier. It's under the steering wheel. It's black and looks like a pack of cigs with a place to plug in a harness. That was my problem. It's not the switch, it's under your wheel next to the warning chime...
hey offtha hook are you talking about the one like right below the steering wheel and the cover that pops off? the one near the steering tilt lever? i dont have a clue what that thing is man. is it the warning chime? hmmm, hey micah, the bulbs blowin off wont make everything go bizzar bro. IF any of your tail lights blow off, the braklight warning indicator appears on your dash. it must be the one offthahook said, but i have no clue if its that thing. do u think it might be some loose connections? but u said even your license plate lights wont work. thats really odd. :confused: . You seem to get all the weird probs. :p just kidding man. hope u figure it out.
the dash licence and rear lights are all the same fuse.
Hey,
I'm with you on this one man. I have the same type of probelm only without the blown 14 fuse. I've checked them all, even the ones that don't even pertain to the problem. All the fuses check out fine. I've been looking for this pack of cigarettes thing and am not finding anything of the sort. If anyone has some pics of this cigarette pack looking thing by all means post them cause I'm about out of every other option and the next step is the shop :(
It's the plate covering the tilt lever. It's held on with a few screws and it just drops sorta. It's black with a 5 pin harness that plugs into it and the chime is right there, too. That has to be it. Hard to describe, right under the steering column.
keep blowing a fuse? replace it with a penny.............
hehehhehe... just kidding, don't listen to that one :)
:pissed:
here is the wiring diagram ffor the dimmer control. 2 parts
look in section b27 for the dimmer control amplifier
here is the other half of the diagram.... if you need the rest of the underdash or engine compartment diagrams, just say so and I'll post em' as well..... Hope this helps
errr... that diagram is for an 88', not an 89'. the only difference is a couple extra options, but the wiring never changed much. if this isn't good enough, I'll post the 89' schematics as well. :D
shit coaster, how many programs do u run simultaneously. damn man u got freaking 500 MBS of ram or what??? :lol
