As the thread title says list your mods. But do not comment on them. I will make a separate thread were you can link to a certain post to comment or ask questions. You can also use the pm feature
Here's the list of my mods.
car: '88 DX hatchback
engine:
38 weber
lx-i valve cover
msd blaster 2 coil
koyo radiator
aluminum rad catch can
pacesetter short shifter
custom 2.25 inch exhaust with Magnaflow cat, and muffler
upgraded grounds with 4 gauge wire, and added a couple of extra grounds
suspension: stock
brakes:
stock lx-i fronts
stock se-i rears
interior:
indiglow gauges
c-pillar bar
se-i armrest
also in the process of being stripped. No carpet, sound deadaning, or rear trim
exterior:
20% tint
random extra stuff:
cut out most of the front bumper support (damaged in wreck before I bought it)
removed hood latch (same as above)
installed hood pins
87' lxi hatchback
engine:
cheap sri (short ram intake)
polished valve cover
msd blaster 2 coil
and ngk plg wires
adj cam gear
koyo high flow radiator
interior:
reverse glow gauges
with custom uv leds
and uv painted needles
carbon fiber gauge cluster
sei armrest covered in microfiber material
sei cup holders
volt meter mounted on gauge housing
ice:
sony pos deck
polk audio db 5 1/4's all around
infinity 1052w 10" sub
lighting audio f&f edition 250.2 amp
exterior:
20% tint all around
painted headlight eyebrows and grill satin black
cf hood
h4 wire upgrade
autopal 200mm headlight housings
oshram sliverstar h4's
pcp clear corners
re painted trim satin black
hood pins
Suspension:
drop zone sport coilovers drop all the way
Tokico HP series shocks
Wheels & Tires:
generic 15" chrome rims
Toyo Proxes 4's 195-55-R15 tires
comming soon:
pacesetter headers
catco cat
88 acura legend
Flowmaster muffler
10 disk changer
NGK V Power Plugs
Duralast plug wires
Accel Coil
NGK 8mm coil wire
other then that stock
coming soon
real short ram intake
ngk plug wires
new speaker most likely pioneers
new deck alpine most likely
ford taurus cup holders
blacked out tint
86' LX sedan
engine:
shortened intake to carb box,
Cut or flipped lid
Custom painted valve cover
NGK spark plugs High Perform.
interior:
Stock gage cluster
89 prelude shift knob.
custom Broken dash..LOL
interior show lights, ( Blue )
ice:
Jensen deck
Jensen 5 1/2 all around
Kenwood 1200w 10 inch sub
Kenwood 1000w amp, two channel.
exterior:
no tint
H.I.D heads, and wire upgrade
hella h4 housing
Polyurethane spoiler
Suspension:
Stock.
Wheels & Tires:
painted stock 16 spoke
comming soon:
pacesetter headers
magnaflow high flow cat
paint
Wheels and tires
custom LED taillights, including third light
1987 Honda Vigor 2.0Si
Engine:
Auto > Manual > Auto > Manual Swap
Low mileage engine swap
Wire tuck (kind of gone now)
Pod filter
Gold rocker cover
Interior:
2.0Si Exclusive interior (minus leather seats)
Colorful gauge cluster lights
Digital Climate control (for cosmetic purposes only)
Alarm
Weight reducted everything behind the dash
ICE:
The sound of the engine
NZ New Honda stereo
The passenger (maybe)
Exterior:
Replaced most body panels with good ones
Converted Vigor rear to Accord rear
OEM Fog lights
15" Alloy wheels
Installed 2.0Si badge under drivers side tail light
Mirrors that fold in/out with alarm
Suspension:
Replaced most of it with stock suspension
Soon:
Silvertop 4AGE ITBs
Heater & A/C maybe?
New 205/50/R15 tyres
Tinted tail lights maybe
i will update mine and edit this post when i do
Engine Specifications:
Stock A20A3 with 157k
OBD1 swapped (chrome tuned)
Golden Eagle Adjustable Cam gear
Colt Tri-flow stage 2 cam
Pacesetter Ceramic headers 4-2-1
koyo High flow radiator
Teg 90-93 red CAI
MSD blaster 2 coil
Accel 8mm red wires
NGK Iridiums plugs
4g map sensor
PRI mounts
Coming soon:
Skunk2 b16 manifold
Drivetrain:
5 speed manual
new clutch at 151k
Custom Short Shifter with poly bushings
1st gen Integra gears with accord 5th
clutchnet 9 lbs flywheel
Exhaust:
Pacesetter ceramic coated headers
Magnaflow high flow cat
2.25inch pipe with magnaflow muffler
Suspension, wheels & tires:
Front: EBC dimpled and sloted rotors with AEM pads
16 inch Rota Slipstreams
Falken tires 452 205/50/16
DC front strut bar
Tokico struts
1.5 inch Neuspeed lowering springs
Rear: Powerstop rotors with AEM pads
SE-i SS brake lines
SE-i rear disk conversion
Justins rear sturt bar
ST front sway bar
poly bushings in the front
2nd gen Prelude arms with new balljoints
Coming soon:
Koni adjustables in the 4 corners
Rear swaybar
Legend rear calipers
Interior:
Prelude 4ws steering wheel
Maroon armrest
SE-i cupholders
Aluminum bezel
JDM Map light
1st gen legend rear view mirror(bit bigger than stock)
PP Guages with white face
skunk 2 knob with civic si boot
OEM foglight switch(not installed)
no trunk panels
coming soon:
OEM foglight switch
Ice
Pioneer deck 50wx4
kicker 6.5 fronts
almani 6*9 rears
10 inch Type R sub
2 way alarm system
Exterior:
20% tint in the back 35% in the front.
H4 Autopal lights
89 integra lip
JDM corners
rear door handle mod(no keyholes)
coming soon:
Clear bumper lights
LEDs in all the front.
Xenon body kit
86 LX-i hatch
Grey in/out
5spd
sunroof
B16 with GSR transmission
2.5" exhaust all the way back
Crome basemap
330/110 billsteins
Legend_master "TypeR" brake upgrade
H4 headlights
Webz
205/50/15 nitto neogens
SE-i grey leather arm rest
SE-i cupholders ( i actually have 2 full sets of these)
Deck
New speakers
tint all round
SE-i disks waiting to go on
1989 Honda Accord LX-i Sedan
Fully rebuilt A20A3 engine, Std.Rod and Main Bearings, Block bored out to 20 Over.
Delta 272 Camshaft
Golden Eagle Adj. Cam Gear
Bosch 4th Gen. Fuel Injectors
Blox Fuel Pressure Regulator
VISION Motorworks Fuel Pressure Guage
NGK Iridium Spark Plugs
8.5mm MSD Wires
MSD Blaster 2 Coil
MSD 6A
Custom 2.5in CAI
AEM ByPass Valve
Battery Relocated to trunk /2ga Wire
Optima Red Top Battery
135 amp Alternator
Alternator Direct wired to Battery
Big 3 wiring Done
Removed A/C and Cruise Control
Replaced stock cooling fans with 2 Hayden 800CFM Electric Fans
Koyo Radiator
Exhaust:
Pacesetter Ceramic Coated Header
2.25 Pipe from the cat. back
Magnaflow Muffler
Magnaflow Resonator
Magnaflow Cat.
Stainless Steal Tip
Drive train:
Swapped from Automatic Transmission to 5 speed Transmission
Exedy Clutch
Energy Suspension Shift Bushings
SRX Rims 15x6.5 12.5lbs
Kumho ECSTA AST Tires 205-50/15
Front KYB GR-2 Shocks
Rear Tokico HP Shocks
Front Trustar ceramic brake pads
Front Brembo Rotors
Front & Rear SUZUKA Stainless Steel Brake Braided Lines
Justin Front Strut Bar
Justin Rear Lower Bars
Gold-Line Springs 2.25 Drop
Energy Suspension Polyurethane Sway Bar End Links #9.8105g
Energy Suspension Polyurethane Sway Bar Bushings #9.5158g
SuspensionTechniques 5/8" Rear Sway Bar
Interior:
Prelude 4WS Steering Wheel
Black Prelude Seats
EQUUS Oil Pressure and Voltage Gauges
Alfa Otto Reverse Glow Gauges
OE fog lamp switch
Center Armrest
SEI Cupholders
Skunk2 Shift Knob
Pilot Shift Boot
Black and Burgundy Interior (Black dashboard, Upper Door trim black to match dash,Black Center Console and Armrest, black accents thru out the car)
Ice:
Deck: Alpine CDA-9851
Doors: MTX 5 1/4 TDX-5202
Rear: Kenwood KFC-6959ie 6"x9" 2-way Speakers
Power: Profile AP400 65ws x 2 Car Amp Bridged to the 10in Sub/ 8gauge power wire
Boom: Sony Xsl101P5 10in SubWoofer
Box: Q-Logic QLH-.6510SS Single 10 Box
Satelilite: Alpine XM Direct Adapter
Misc. 40gb iPod
Exterior:
Hella H4 Headlamps
Sylvania SilverStar Bulbs
Bitesize LED sidemarker bulbs
JDM Corner Lamps
Clear Turn Signals
SilverStar Turn Signal Bulbs
89 Integra front lip
Hella Optilux 1100 Fog Lamp Kit
OEM Window Visors
Front Door Handles Replaced With Sedan Rear Handles
Coming Soon
SEI Rear Disc Swap
1989 montery green metallic coupe
sei dark grey/black leather interior swap(twice)
Bitesize leds dash, replaced all interior lights with blue leds and UV needles
Eclipse CD8445 headunit with serious sat radio
pheonix gold xs series amps, jl audio 12w6 subs, boston acustic mids and tweets
koni reds converted to yellows all 4 corners with ground control coilovers
new poly bushings in the suspension
powerslot sei rear upgrade with robs AEM civic 12 inch front kit
stainless steel brake lines
2.25 inch exhaust from header to muffler with magnaflow muffler and resonator/cat
JDM B20a 5 speed with Victor x intake, obd1 upgrade, ludespeed turbo kit running T3 48/60 precision intercooler, 70mm edelbrock TB,
JDM corners
JDM bumper poles
JDM map light
Euro center console
dc strut bar-silver
lots more i cant remember
89 Honda accord DX a20a carb 250k miles currently
accel coil
flipped lid
cut muffler {not my doing}
JVC head unit
JVC 6.5" 3ways front/rear
future to include
1.75" springs
stiffer shock/Struts
tower bars front/rear
undecided wheel/tire combo
6 point rollcage
rear disc brake conversion
drilled/slotted front rotors
Weber carb
head studs
head/intake port/polish
dual friction clutch/pressure plate
rods and pistons {depends on rod affability}
high speed balance rotating assembly
msd ignition box
100hp shot nitrous kit
and maybe more.
1989 Honda Accord 2.0Si [DRE96]
My race car hahahaha
HOW IT WAS....
Carb SOHC A18A Engine
Automatic Gearbox
Brown interior
Fucked boot and rear bumper
Rust in a few places But overall good paint
$300 from a guy who wanted it gone from under his tree
Mods i have done are:
- Complete EFI swap. tank lines complete car wiring loom from a 1988 2.0Si
- Rear Disc Swap cause drums are gay
- B20A Engine installed with 5 speed swap
- Custom Short ram intake and POD filter
- 1986 F1 special edition interior installed
- OEM JDM Digital Dash Installed
- OEM JDM Climate Control Installed
- Koni Yellow Damper Adjustable Shocks and King Springs all around.
- 2nd Gen 14" White prelude "Aero" wheels
- Prelude Adjustable Camber Upper Arms
https://www.3geez.com/forum/showthread.php?p=852569 <-----Build Thread -----
Car Audio
- Panasonic MP3 cd Headunit with full set of line outs
- New Gold and Silver Battery Terminals
- 4GA Wiring to alt/amps. 8GA to fuse box
- 12" Pioneer sub in custom tuned slot ported box
- Random brand 300w rms amplifier for sub
- Lanzar vibe 4X100w rms powering car speakers
- Random 6.5" Speakers in front doors
- Pioneer 6X9's in the rear tray in the OEM 6x9 holders
Future Mods
- OBD1 Swap
- Shorten rear Konis
- 93 vigor rear swaybar
- larger 4g accord front swaybar
- B20A engine rebuild
- Capactitor and Fuse blocks for car audio
- Grey Rear Bumper!
1985 Honda Accord 2.0Si [TA5877]
The family cruiser/GF's car
HOW IT WAS....
B20A, DOHC Gold Top 160HP engine
Automatic Gearbox
Brown interior
Mint grey paint, Faded boot paint
$1200 with 140,000kms and DIGITAL DASH
- Sold Digital Dash to pay for the car, basically the car was free.
- Purchased 2.0Si exclusive parts car and installed the leather exclusive interior
- Install my old accord toyota rims
https://www.3geez.com/forum/showthread.php?t=65009 <-----Build Thread -----
Car Audio
- Random Brand CD/MP3 Headunit Powering front and rear speakers
- OEM but still working 6.5" Speakers in front doors
- Random 6X9's in the rear tray in OEM 6x9 holders
- Temporary 8ga Wiring
- Kenwood 150W rms amp
- Cheap "rampage" 12" Sub in Sealed Box
Future Mods
- Auto to manual swap
- Lowering Springs
- Upgrade Battery terminals/amp wiring/engine earths to 4GA cables
- 85-87 Accord OEM Accord Front Lip
- OEM Climate Control
stolen from https://www.3geez.com/forum/vbpicgall...p?do=view&g=83 my 3geez garage hahahasDFhasdhg
description: under renovation
86 DX
5 speed
Pioneer top shelf 1994 model hi power casette tuner with low impedance outs
Best Buy brand 6.5 speakers
15 inch steelies withj P205/60/15 on 4 corners
Weber 38 with spead bore intake manifold
De-vaccuumed, custom made PVC
Painted Mopar blue valve cover from the LX first resto
Description: under remodeling
86 LX
Auto, fine tuned
JVC Kamelion CD
Kenwood 5.5 inch in the door
Lightening audio 6.5 in the rear deck
SE-i console with fat armrest
Spoiler moulded into the decklid
All side mouldings and both bumpers painted solid body color
15 inch mesh spoke, very light alloys painted gunmetal grey
P205/70/15 tires
Weber DGV 32/36 manual choke
Custom ported intake manifod
de-vaccuumed
Gold top valve cover rare, in excellant original condition
GE ACG cam gear (set oem at this point)
Fresh valve job, head milled dangerously out of spec
Exhaust ports cleaned up
DC header
Smitthy's style 32 inch crimped steel glasspack
Generic exhaust tip, baffled with a slight curve
JDM B20A
Wiseco 9:1 Compression Pistions
Pauter Connecting Rods (H23)
ARP Head Studs (B18A/VR6)
Ferrea Custom Valve Train (B18A/Custom)
Vortech FPR
Vortech Fuel Rail
Vitec Wires
MSD 6AL Ignition
MSD Blaster Coil
Edelbrock Victor X Intake Manifold (polished)
Edelbrock 65MM Throttle Body
N/A
Engine Misc.:
N/A
Turbocharger & Induction:
Garrett T3 Super 60 Turbo
Tial 35MM Wastegate
Greddy Type S Blow Off Valve
Spearco Front Mount Intercooler
Ludespeed Turbo Manifold (Sold)
N/A
Fuel & Tuning:
AEM 30-1040 EMS (Sold)
AEM Wideband
RC 550 CC Injectors
N/A
Exhaust:
Custom 3" Exhaust
Custom 3" Downpipe
N/A
Drivetrain:
Clutch Masters 4 Puck Clutch (B20A5)
Fidanza Lightened Flywheel (B20A5)
Quaife Limited Slip Differential (B16A)
N/A
Weight reduction & transfer:
N/A
Koni Struts
H&R 1.5 Lowering Springs
Suspension Tech F/R Sway Bars
Custom Rear Strut Bar
DC Sports Front Strut Bar
17” Racing Hart C2 Evolution Wheels
Nitto NT-555 205/40-17
N/A
Interior:
Infinity Perfect 12 Sub
Memphis ST-300 Amp
Memphis ST3004 Amp
Memphis 6.5’s Front
MB Quart 6 X 9’s Rear
1 Farad Lightning Audio Capacitor
Optima Yellow Top Battery (In Trunk)
Sony CDX-C90ES Digital Head Unit
Sony 10Disc Changer
Custom Triple Gauge Pod
Auto Meter Lunar Boost Gauge
Auto Meter Lunar Oil Pressure Gauge
Auto Meter Lunar Water Temperature Gauge
Auto Meter Lunar Volt Gauge
AEM Wideband Air/Fuel Guage
Blitz Turbo Timer
Pace Setter Short Shifter
SEI Arm Rest
N/A
Exterior:
JDM Side Markers
N/A
Stuff Laying Around:
PRI B-Series Mounts
Drive Shaft Shop Axles
Full SEI Rear disc setup
Misc Black Interior
2 Full B20A Motors
1 Spare B20A Tranny
Brand new black carpet
The list goes on!
here is a list of the modifications on the car,there are a lot more,I just can't remember everything over the last ten years ,I do all my own work,including engine,body work,custom parts,interior,etc.
list of some of the mods
engine
cam shaft
painted valve cover
custom pistons[were already done]
custom cowl induction system
lots of aluminum parts made by me
lots of purple LOL [anything purple on the engine was custom made by me]
ported and polished cyl head also flow benched
ported 88 accord iron exaust manifold
drillled aluminum battery hold down
drilled aluminum sparkplug wire holder
vaccume storage in car
aluminum fuel log
aeroquip line and fittings for fuel and valve cover breather
holley fuel pressue regulator specially ordered for low pressure
norskog digital fuel pressure gauge and sender
new gates belts and hoses
new timing belt
all new gaskets throughout engine
carb was rebuilt(needs it again)
new motor mounts
new plug wires
ngk plugs
custom exaust from manifold back with cherry bomb muffler and custom aluminum mounts
theres a lot more but thats what I can think of in the engine for now
interior
custom modified 89 lxi seats with modified tracks
custom leather upholstery throughout with cloth inserts on doors and quarters
vintage equus tach with custom door mount
norskog digital fuel pressure gauge mounted below tach
sunpro vintage style gauges in custom aluminum panel
aluminum trim rings around factory gauges
neon in gauge panel
factory cruise almost finished installing
power mirrors added
window cranks made from brigs and stratton connecting rods
altimeter
overhead console with switches for controlling cooling fans and XM radio
aircraft switches mounted in center console control stereo,boost fuel pump and rear fog lights
redone headliner
custom aluminum rear brake light
rear inner quarters extensivly modified to get rid of change pockets and custom upholstered inserts
courtesy lights in rear quarters
clarion head unit
polk speakers
sony amps and boss crossover integrated into body structure
grab handles from lxi sedan for headliner
hatch completly reupholstered in tweed and custom fiberglass inserts for coleco game system
body
extensive work to smooth body and repair accident damage and all dents
all rust damage repaired in insert under rear taillights
Xm antenna integrated into roof lines
shaved antenna and rear washer
custom work done on front bumper and grill,bumper was restored.
rear fog lights custom made
B&M PS cooler integrated into grill
vintage hella yellow fog lamps restored
blazer ultra blue sim HID lamps for driving lamps with amber bulbs for turn signals built in
european turn signals with built in parking lights
vaccume powerd cup holder that hides under seat
ford escort spoiler with radio antenna hidden inside
custom switching system for fog lamps operate automatically
will be painted factory greek white with black below the trim
car is in primer right now with all trim removed ready for final color coat
wheels
air craft wingtip lights for side markers
washer tank moved into car with custom tank in passenger foot well
and filler in cowl under hood.
projects working right now
dual SU carbs with custom manifold
aircraft oil cooler with thermostaic control,force air cooled
lots more braided line
custom wiring harness to integrate alarm,stereo and many car functions
prelude aluminum valve cover(hopefully)
modified 94 geo prism wheels
custom pedals need to go in
odyssey battery in tool box battery holder
changing dash color and cloth insert color
1984 Honda Accord LX hatchback
engine
stock ES2 engine with 240,xxx miles on it
replaced clutch
replaced camshaft
remanufacteured carb
open air cleaner with K&N filter
racing radiator with slim fan
2.5 inch piping from header to magnaflow high flow cat
no resonator
"mini turbo" muffler (thats what the shop called it so i dont know)
rear disc conversion (coming soon)
exterior
2 tone silver and black cherry
debadged
5% tint on rear three wndows
17 inch sokudo adr rims
2 nexen tires
2 falken tires
FOHA spoiler
vestatec front bumper
H4 conversion silver projector housing
Klight HIDs
benen front and rear tow hook
interior
sony HU
2 - 5.25 inch alpine type s 2 ways
4 - 6.5 inch alpine type s 2 ways
2 - 600 watt mtx jackhammer 10inch subs in custom box
1 - Rockford Fosgate 900 watt amp
2 - sparco seats (driver and passenger)
momo jet steering wheel with NRG quick release
black carpet with sound deadening
all interior painted flat black
reupholstered custom door panels
black headliner
rear seats done to match front racing seats
In Progress and Under Construction:
Vehicle: '89 DX Hatch
Engine/Exhaust/Driveline:
Stock A20A3 Block
P&P A1 Head w/ stock springs/valves/retainers
Colt Stage 2 Cam (coming soon)
GE Adj Cam Gear (also coming soon)
ARP Headstuds
LX-i Valve Cover
Twin Weber DCOE45's on Custom Manifold
Removed A/C
Removed PS
DC Header
Test Pipe
Custom 2.25" exhaust to crap MegaFlow muffler
Auto-to-Manual Swap
Suspension/Brakes/Wheels:
B&G Springs
Koni Reds all around
BFG SS brake lines
Upgrade to SE-i brakes front and back
Axxis Metal Masters Pads all around
Brembo c/d rotors all around
Proline 15" wheels on Kumho VictorRacer V700R's (205/50-15)
Interior:
Removed heater core
Removed all HVAC and radio controls
Custom Headliner and Doorpanels
Off-Black Rear plastics and seats (from Phoenix Red '88 DX Hatch)
LX-i Front Seats
Exterior:
35/20 Tints
Completely debadged
Custom Fender Lights
Custom Corners
Custom Bumper Lenses/Housings
Painted Grill
626 Lip
Uni-wiper (ftw)
ENGINE Mod List
1.LudeSpeed Manifold
2.Costom APR Head Bolts
3.Costom Web Cams
....................Intake......... Exhaust
valve lift........ .420......... .430
Duration:........230............237
Duration@050 : 200.........205
Lobe Center.... 110...........112
Intake opens -10 Before TDC Exhaust opens 34.5 Before BDC
Intake Closes 30 After After BDC EXhaust Closes -9.5 After TDC
4. T04e 50A/R 57 Trim and .63 A/R Turbine
5.OBD-1 converion Chipped (Crome)P06 Ecu and B18A/B distributor
6.Stage 3 6puck clutch and plate
7.Precision 580cc injectors
8.B16 intake ported to 68mm
9. 68mm Throttle body
10. Two F22 cam gears
11. 35mm 8psi waste gate Tial knock off
12. custom intercooler
13.Ggay 2.5 intercooler piping Universal Kit
14 Greddy knock off Type-RS Blow Off Valve
15. custom front crossmember and front motor mount
16. OBX UNDER PELLEYS
17. Adjustable FULE PRESSURE REGULATOR
18. 2.5 Down pipe to 2.25 CUSTOM CAT BACK WITH Magnaflow High Flow Muffler
19. Civic EK9 Dual Core Aluminum Radiator With two 1100CFM 12in FANS
EXTERIOR MODS:
1. COMPLETLY CUSTOM NO KEY DOOR HANDLES
2. CLEAR BUMPER LIGHTS
3. JDM CORNER LIGHTS
4. JDM FOLDING MIRRORS
5. JDM FOG LIGHT SWITCH
6. H4 PROJECTION HEADLIGHTS
7. SEI ARMREST
INTERIOR MODS:
1. PIONEER DEH-7700MP WITH XM AND I POD ADAPTER
2. DIAMOND AUDIO M5 MID/THWEAT FRONT/REAR DOOR'S -PIONEER MID BASS IN BACK DECK POWER By ROCKFORD FOSGATE POWER 800@4 AND 800@2 AMP'S
3. DVD AND 5.6 PASSENGER SIDE VISOR SREEN AND 12.1 DROP DOWN SREEN.
4. APC STEERING WHEEL
SUSPENSION MODS:
-DROPZONE 2.25 DROP WITH KYB STROUTS
-SEI REAR DISK CONVERTION , -17 BSA 356 RIMS BLACK/SILVER WITH 205/40/17 Tire's
