Re: cleaning up the frontend
looks pretty good
should ditch that front plate or move it to the side and i might have that light bulb socket that u need if u have the light casing ill check to see if i still have it if u want
yeah doesnt look bad...when i did my oil pan i used a OEM honda gasket and a oil pan off my other motor...so far it works fine.
Front end look real good.
Yeah the bastards at the yard here use that same tool to drain the oil that leaves a rubber plug in the hole. I wasn't too happy when I got my engine from there as I thought "cool a new pan with no dents in it" only to find that damn rubber plug. grrr.
so, your front turn signals.. you sprayed them with spray paint.. or what?
86ccord
i used VHT Niteshade its pretty much tint in a rattle can light can still come through it an all that. it says on tha can though more than 3 coats is illegal
Dark_Accord
looks pretty good
Thanx Homie that would help alot
Juggalo88Accord
oh alright.. thanks i think i may go get some.. you got it from local parts store or what?
how many coats you use?
86ccord
I got mine on ebay im not sure if tha parts store would have it or not if you type Nite-shade into google youl find alota online stores with it. I Put on 3 thick coats then 4 coats of clearcoat wich darkend it a good amount.
sup man i found a bulb socket that should work just fine pay shipping and its yours
