Ok, I need to restore My suspension bushings. Something I have overlooked before. Does anyone know of any kits that can be purchased or will I have to buy them all individually? Is there a urethane solution?
umm, i know there're some endlink bushings and sway bar mounts from energy suspension that fit w/ minor mods, i believe. i know picopop did up his bushings awhile ago and made a whole thread about it.
individually u can doo all the front ones in poly
^ Got any links?
https://www.3geez.com/forum/showthread.php?t=65258
I am working on something for the rear LCAs as well. Will post it up when I find the solution...
dont get poly...youll end up replacing them after they deform...you can get poly for sway bar and endlinks..other than that oem is the best...unless you go spherical..
I haven't had a problem with mine. They've been on there for about 2 years now. Some of the oem ones I put on in 06 needed to be replaced in less than a year. Car handles better on the 2 year old poly bushings than it did on the new oem. I would try to stick with prothane though, the ES seem a bit soft.
if you have the time, a set of vernier calipers
measure up the bushes and go to a parts place and go thru the parts book.
i couldnt find accord rear shock lower bushes and ended up getting ef civ bushes and cutting a few mm off each end of the sleeve
there will be a bush that fits or needs minimal mods to fit
The rear LCAs can be done with 2 civic rear UCA kits (8-307) and the inner sleeves from the Accord rear LCA kit (8-312). Fit is perfect, no cutting required. The only reason the inner sleeves need to be changed is that the accord bolts won't fit through the smaller civic inner sleeve holes.
