Re: sign of a dying starter?
Aha, more good information, kinda sounds like my problem too. Diagnostics + MN/December = numb fingers
Originally Posted by anchovies
Main relay from autoparts stores is like $30. Less than that if I remembered correctly.
Why replace it when you can fix it in about 5 minutes??? (search for "Main Relay")
Yeah, not likely. Typically, parts like that, which are vehicle specific, are MORE than dealer list. Or they are just crap parts that you don't want in your car anyway. Oh, and the main relay doesn't have ANYTHING to do with the starter. So if the description is correct, it's NOT the mainrelay causing this problem. It's probably the starter contacts or the ignition switch.
