roodoo2
The venturi in that carb, man I wish you had some pictures cuz some of those had booster venturies, more than one on some models.
They just set in the top there and are supposed to be spewing fuel downward, sometimes they flip around and will spew down the side or even upwards. The only thing that really holds it is a small staked spot and the tophat.
How is it loose?
The vacuum advance being off could have caused it to spit back esp if it was cold. Not enough advance at off idle would make the engine not want to take any gas very quickley.
Spitting back normally is an indication of being lean isn't it Cygnus?
