Re: Gave up on the A20...
$3000 for a 160hp motor? Isn't that a fairly high compression engine to be running a turbo on? I'd think a turbo A20 would be far more cost effective. Especially since we have members putting down over 200hp with turbos and fairly mild builds. Also since you're doing Hondata and going to built mounts, etc. AccordTheory probably still has his whoop-ass A20 turbo manifold for sale.
You're going to be starting with a used, $3000 motor, then doing everything to that motor that you'll wind up doing to the A20. And then when you're done, you'll still have a used motor. You could put together a mildly built A20 that will probably handle the boost better for that same $3000, and it will be a totally new, refreshed engine. Then put your Hondata computer on it, and all the turbo fabwork that you'll need on that B-series anyways... save the hassle of the mounts, axles, shift linkage, speedo, etc etc... and probably have near the same horsepower.
c1 is an OK boost motor, the b18c5 is the one you wanna stay away from. If you ask me (And trust me, no1 ever has or will) id stick with the a20. Far stronger, and only lacking in performance valve train parts.
Hmmm... well IDK Bisimoto said that his company can make any parts i need or want but he said that he never buildt a A20 before and only has cams for the motor in production I have aslo thought about a B16A and just doing a OBD1 conversion on that yes I know it has next to NO TQ but it would easyly put the car into the 11s and still be somewhat streetable thats not going to happen with a A20
We are actually working with bisimoto very soon about getting some parts made. We have a head and a cam, we just need to put the parts together and get them sent in.
God
A B16A will not get the car into the 11s. Might get you into the 14s if you're lucky! Or are you talking forced induction still?
When you say cost effective what do you mean? Yea, it will cost you about 3-4k to turbo your 3g safely and use as a d/d, as where if it was a civic it would be about 2k to do the same. But if your talking about buying a 4k motor and the tranny for it, custom axels, custom mounts, custom wiring, the parts to go turbo, plus rebuilding that motor to support boost your going to spend like 7-8k. How is that cost effective? plus since you made your car go faster you should make is stop faster to be safe so a full disc brake setup with some drilled/slotted rotors would help but will cost more. For that same 7-8k you can take your A20 and have a full turbo build done ( by full build i mean built motor, built tranny, clutch, obd-1 swap, manifold, all turbo parts, wiring, etc..) and still spend about 4k. Then take the other 3-4k and do a full disc brake setup, full suspension upgrade, better wheels and tires, plus do cosmetic things that make the car look better like new paint, body work, tint, interior work, audio system, etc... Basically what im trying to get at is this. You can spend 8k and have a older not so nice looking car with old/worn parts and a turbo JDM B18, or you can have an older great looking car with all new and performance parts throughout the whole car with a turbo A20 for the same price. Which one do you think is cost effective?? Plus if you go with the second option of sticking with the A20 and all, by the time your done your car will basically be new, plus it will be turboed, have great handling, look great, etc. which in my opinion getting a car like that isnt bad for 8k, plus still has that old school look to it. If I had a 3g with 8k to spend then thats definatly the way i would go, but thats just me.
i think Little xox bitt said it all my friend...plus a A20 Block alot strong then your B,D Series block...
If you have 13k set aside you can build a very nice motor and setup for this cash.
When I said I have 13K thats just for motor mods I know about the other things you have to do to be safe. Yes no matter what motor I do it will be forced induction I already have a T3/T4 turbo for the car. Im looking to do around 375 at the wheels and I just dont see that happening on the A20 and still be streetable yes I know there is a A20 in the 9s and a few in the 10s but they are full race only cars Im wanting something like a 11.4-11.6 and still be able to take it out on the weekends or for cruiser night. The same website I can get a B16A for $1700 which isnt too bad because it comes with everything you need to do the swap minus motor mounts but Im going to have those custom made. Now i figure with a B16A with the Y1 tranny(comes with engine package) with these mods
Eagle 1.8L stroker kit(9.3:1 compression)
ported and polished head
Skunk2 Mani
T3/T4 Turbo kit(12-14psi on the streets, 22psi when at the track on C16)
Skunk2 70mm TB
Skunk2 Stage 2 Turbo Cam
The guy at skunk2 said that even with the street boost I should easyly be way over 350 and he said if i didnt hit around the 470-480 mark it would be a shock to him.
You said a buildt tranny for the A20 where can you even find stuff to make you tranny stronger other the just swapping gears around. You will never find a LSD for the A20 and having forged gears forget it. Yes I will admitt if you are looking for a DD that is fun like a low 14 second car you can get away with the A20 but if you are looking for a power house a motor swap is the only way to go.
Then why not just get a civic?
Naf's Asdf
my thoughts exactly...
Naf's Asdf
The same reason you dont you want to be different then every other tuner out there. I understand you guys are dedicated A20 people and maybe some day in the future people will start building more and more powerful A20s on the street but right now I just dont see it happening
I get that. But with the setup you're going for, putting it in a civic would net you a faster car costing you less money and less work. If you truly want something unique, I don't see how that's going to happen with a B16/18. (unless you put it in a 1g hatch, that'd be a killer ride) ;)
Anyhow, whatever you end up with I hope you get what you want out of your project :)
Your forgetting about the cost of the custom work. Even if you get parts for cheap, you will spend 4k just on fabricating mounts, axels, wiring, etc... Stick to the A20 and keep the 3g true, if not get another car like a civic or integra so you will have yourself tons of money.
I like the Turbo A20, but if you actually go through with a B-series in your 3gee, then I think it's pretty bitchen, too. Not a lot of people with a B-series 3gee.
b4 you bern a hole in your pocket buying a shitty b-series if you want power go "g23". you'll spend alil UNDER half your savings and you will b able to beat s2k's, k24's and mustangs! import tuner feb. 09 issue did a story on a $5,000 "g23" build and yieded 248.6hp & 181.2lb-ft torque N/A! a b18c would run u bout 5grand with less hp&tq, and k20 type-s bout 6-8grand also with less hp&tq. good luck with whatever you choose to build! with stock head and block the comp. comes out to bout 8.8:1 perfect for a turbo!http://www.preludepower.com/forums/s...&highlight=g23
or he could buy a "shitty" LS b18, boost the shit out of that and not have to deal with all the frankenstein motor bs :thumbup:
then theres the whole getting the F block to fit in the 3g....
I say if you want to keep the 3g stick with the A20...there are plenty of knowledgeable people here who can help you with that.
i just want to see your work.
LiTtLe xOx BitT
word
God
i hate to say it but you must not search very well.. there are guys on here that are turbo that are running LSD's in there tranys...
If you have so much time and money and you want power, why not drop a H22 if your making custom mounts and all? That solves your power problem and im shure it will meet your other aspectations, and I think there are a few sucussfull H22 swaps on here. [correct me if im wrong] I know I would love to have the money to drop a H22 but that might just be me.
I'm not seeing how an A20 tranny will handle 375HP at the wheels. What did JohhnyO do to his to make it work?
The other thing to think about here is support; which by that I mean tuning and other knowledge about the motor you will be running. Whatever motor you run will need to be built and tuned by someone who knows what they are doing. So I would talk to whomever will be doing this work and see what they are familiar with. If they think they can boost an A20 to those levels reliably, then yeah, go for it. But if they don't have any experience with a boosted A20 and they end up roasting the motor during tuning, how good a decision was the A20 then? And who will end up paying for this mistake? Not the tuner I assure you.
As cool as a turbo A20 would be, it will be harder to find competent support for.
C|
