Re: Fuse On Radio Went out
woh take out the aluminum foil first your calling for a fire. first of all check all your connections and make sure nothing is shorting out. it definitely sounds like you have a short somewhere. if you have a multimeter try checking the resistance of each speaker and triple check all of your connections. as for the fuse i know on my deck it just takes a simple mini-ato fuse that can be picked up anywhere.
Head unit fuses never blow by themselves so yeah disconnect all the speakers 1s and hook a house speaker to it maybe to test if the headunit is putting out audio, if theres no sound your internal amp shat itself and u may need to use an external amp from your rca's if any.t
What do i find a stock cd player in? That will fit my car?
