Accord of the Month Nominations - April
YOU MUST PROVIDE A MOD LIST, A DETAILED PARAGRAPH, OR A LIST OF WORK DONE TO THE VEHICLE YOU ARE NOMINATING.
Its time to nominate your favorite ride for AOM: April 2009
Check out the Rules & Regulations
How to Nominate a Vehicle for AOM
The following past winners are ineligible for nomination:
July 07 - Wickedaccord
August 07 - MessyHonda
September 07 - Hazwan
October 07 - 2ndGenGuy
November 07 - Frantik
December 07 - Catalyst
January 08 - twhonza
February 08 - MIK3
March 08 - AccordB20A
April 08 - Mushroom Toy
May 08 - 89turbo'ed
June 08 - ghettogeddy
July 08 - Knarg
August 08 - bullard123
September 08 - TWOLOUDNPROUD
October 08 - 84Accord
November 08 - Zogzag
December 08 - carotman
January 09 - 3gmodifier
February 09 - LX-incredible
March 09 - Pico
Members must have 50 posts in order to nominate someone
Duplicate nominations will be deleted
Posts made that are not nominations will be deleted
Invalid nominations will be deleted
There is no need to second a nomination! If a nomination is valid, it will proceed to the voting stage automatically.
Re: Accord of the Month Nominations - April
I would like to nominate
Turabaka! For having such a clean Accord Hatchie!
Information on said vehicle .
1988 Honda Accord Hatchback DX
Engine Specifications:
- 38 Weber Carb
- Delta 272 cam
- ported intake manifold
- MSD blaster 2 coil
- Accell super stock 8mm wires
- Optima red top starting battery
Fuel & Tuning:
- Holley blue fuel pump with regulator set to 3psi
Exhaust:
- Pacesetter header
- 2.25 inch mandrel bent exhaust
- Magnaflow cat and muffler
Drivetrain:
- Pacesetter short throw shifter
Weight reduction & transfer:
- stripped carpet and sound deadening
- full vac removal
Suspension, wheels & tires:
- Tokico blue shocks
- Sprint springs
- Acura Vigor rear sway bar
- 2g prelude front upper control arms
- SE-i disc brake setup
- 215/45-16 Falken Azenis tires
Interior:
- stripped carpet
- sunpro water temp, volt, and oil psi gauges
- indiglo gauges for tach, speedo, and temp
Exterior:
http://i232.photobucket.com/albums/e...a/DSC_0098.jpg
http://i232.photobucket.com/albums/e...a/DSC_0102.jpg
http://i232.photobucket.com/albums/e...a/DSC_0107.jpg
http://i232.photobucket.com/albums/e...DSC_0116-1.jpg
http://i232.photobucket.com/albums/e...DSC_0119-1.jpg
http://i232.photobucket.com/albums/e...DSC_0120-1.jpg
http://i232.photobucket.com/albums/e...a/DSC_0110.jpg
http://i232.photobucket.com/albums/e...a/DSC_0091.jpg
http://i232.photobucket.com/albums/e...a/IMG_0050.jpg
http://i232.photobucket.com/albums/e...a/DSC_0054.jpg
I Nominate Tdurr to the AOM because He has done some unique moods and have put to much effort to ignore it.. Well just look at it :D
Moods
*Engine
* Rebuild +20 overbore
* Pacesetter headers
* 2.25in exhaust w/high flow cat
* MSD Coil Pack
* CAI
* Delta 272 cam
* NGK Plugs+ Wires
* Painted VC
* Removed AC+lines
* removed Cruse Control
*Outside:
* 17in ASA rims
* Tinted Tails
* Tinted Front turn signals
* Legend front lip
* Domo, ImportAlliance, and Megan racing stickers
*Interior:
* Dyno matt cab(minus doors)
* Recovered seats(4g worth of leather)
* Moded dash for 7in Tv
* Oil Pressue, + A/F Gauges
* Pedal Cover
* 2 10in subs
* Gutted trunk besides subs+tools
*Suspension:
* Tokico blues + Ground Control sleves(rear)
* Unknown struts + ebay sleeves(front)
* Lowered around 3in.
* Rear strut Bar from a cb7(Megan racing)
* stock sway bars(for now)
*Other Mods:
* Rear disk conversion
* Slotted(front) & Drilled(rear) rotors
* Battery moved to the rear
* Power Coated VC
* and some other things i cant think of...
http://i91.photobucket.com/albums/k3...ples/Tdurr.png
http://i91.photobucket.com/albums/k3...les/Tdurr6.jpg
http://i91.photobucket.com/albums/k3...les/Tdurr3.jpg
http://i91.photobucket.com/albums/k3...les/Tdurr8.jpg
http://i91.photobucket.com/albums/k3...les/Tdurr9.jpg
http://i91.photobucket.com/albums/k3...les/Tdurr5.jpg
http://i91.photobucket.com/albums/k3...les/inside.png
http://i91.photobucket.com/albums/k3.../headreast.png
http://i91.photobucket.com/albums/k3...les/Tdurr4.jpg
I would like to Nominate RendonLX-i with his Turbo'd Sedan
Engine Specs
Fully rebuild A20A3 /9:1 compression
B&M Fuel pressure Regulator
8.8 Accel spark plug wires
NGK G-powers
4Gen Accord Map Sensor
Delta Camshaft 272
GoldenEagle CamGear (not Installed)
Mallory 6AL/ SS blaster coil
Custom Ground kit
93 Civic Racing Radiator
12inch Slim Fan
DC strut bar
Ebay Catch can
Turbokit
Dsm T-25 2gen .48 trim internal WasteGate
SMIC 2g DSM
Custom Charge pipes
Custom Log Type Manifold By (JUSTIN)
HKS SSQV Bov
450cc Blue Tops Controled by S-AFC
2.5 Inch downpipe to 2.1/4 catback
Greddy Full Turbo Timer (not Install)
Tuner Toys StealhMode Oil line kit
Turbox manual Boost Control (not install)
Autometer: Boost,Air Fuel Ratio, Oilpressure Gauges
Suspension
Kyb Gr-2
Eibach Sportline 2.5inch drop
Del Slow SwayBar Bushings
Vigor Rear Swaybar
SS Braided Brakelines
Powerstop Rotors
93 accord Lower tie bar
Ingalls camber kits in front
Rear Adjustable Camber kits in back
All Rolling in Motige Trak Lites Wraped in 205/50/15
Dulops Dz101 Drag Radials
Interior
Nopi Reverse Indiglow Gauges/ Bezel
All Stock interior
PaceSetter Adjustable Short Throw
JDM Real type R Shifter Knob
SEI ArmRest
3g Lude Seats
3G Lude Steering Wheel
The Knocks
Phoxian Gold 1000watt 4 Channel
All 4 Componet MB QUARTs
Kenwood Amp 2 channel Mono Digi
2 12 kenwood Swirl subs
2gauge wire kit
power cap
Indash 3.5 power acustic dvd/vcd/cd/mp3/player only running Amps not off the stereo
9.2 Flip Down Screen Boss
Exterior
Si Blue paint w/ a hite of purple
lazey pearl
87 Crx si Clear Bumper lenses
custom rear bumper with mesh
Maxspeed Turbo muffler
93 Accord Front lip
HID H4 Conversion kit w/ 6,000k
Hella H4 Housings
Battery Relocated kit
http://b6.ac-images.myspacecdn.com/0...32991726_l.jpg
http://b6.ac-images.myspacecdn.com/0...32992686_l.jpg
http://b8.ac-images.myspacecdn.com/0...32998248_l.jpg
http://c2.ac-images.myspacecdn.com/i...2f671546ad.jpg
http://c2.ac-images.myspacecdn.com/i...812127eb81.jpg
http://c4.ac-images.myspacecdn.com/i...d8b1a50567.jpg
http://memimage.cardomain.com/ride_i...0078_large.jpg
