I have an 89 SE-I that has developed an oil leak. It was leaking while driving and it turned out to be the O-ring behind the cooler where the filter is. It is now leaking while parked in the driveway. I also changed the O-ring on the dist. As oil is all over the place, it's hard to figure out where it's coming from. The timing belt is dry. I guess my question is, if the oil pan gasket is bad will it leak when parked. Same question for the rear main seal. I' m thinking that the oil level wouldn't be high enough while just sitting there.
Thanks for any replies.
Forrest
