Re: B-Series swaps and axles
nice!
when my mounts finally get here ill try out the 91 pre;lude drivers side with the 89 integra passenger side without either dust rings
I used an 86-89 Accord axle on the left side with an 88-91 Prelude inboard joint(to have the full splines).
I don't know if the B20A is placed in the same position as you B series swap but when I tried the full 88-91 Prelude axle, it felt like it was a bit on the short side.
carotman
It is a little shorter than the accord passenger side, but longer than the integra ones that were used previously by others.
I believe the accord passenger side was 24 3/8 and the prelude driver side was 24 5/16.
probably the best setup would be an accord passenger side axle with either the fully splined integra or prelude inner joint.
I did not want to start buying axles and taking them apart so that is why I went with just the prelude axle especially since this is a temporary fix.
