FS: Lambo accord..It has to go!!!
Well as you know a while back i was floating the idea of keeping/selling. So it's official. The car is now for sell. I have the vid to show it's up and running. i have 4 car projects (and all are major ones) i can't finish them all with out selling one and with the autox and drift events with the points race going on i really don't have the time. I'll be looking to get $4,500 for it O.B.O. the dizzy still needs to be welded . This car is set up to run boost as this was a turbo project PM and/or email me at [email protected] i', offering it up to the 3geez community first. If it dosent sell on here then i will put it on ebay.
interior
Re-painted dash and all vynal pieces
reupholstered seats with "H" emblem headrest
formfit carpet
custom floormat
carbonfiber shifter
carbonfiber bezel gauge
reverse-indiglo gauges
custom mesh rear speaker cover
exterior
90-93 Teg Blackwidow kit I (Custom backbumper)
Clear taillights(made by me)
Clear corner blinker lights
shaved side molding
shaved badges except for "H" on trunk
flip flop trunk
lambo doors
custompaint w/silverflakes
ENGINE A20A1 (REBUILT) 1000miles maybe less
auto to 5-speed swap
carb to efi swap
short ram intake
Port and polished head
Polished exhust
pacesetter ceramic coated header
UnorthodoxRacing Flywheel (less than 9lbs)
diamondracing pistons (9.2:1 CR)
eagle H-beam rods(LS Integra)
Coltcam Stage 1 turbo cam
hi-flo cat w/ custom 2.5 exhaust
apexi muffler
ngk plugs
accel ss coil
Golden Eagle 440 Adjust-tru adjustable cam gear
B&M fuel regulator w./gauge
SUSPENSION/WHEELS
groundcontrol coilovers(2" drop)
Ingall'scamber kit
Koni reds in the front
Revalved Blistien in the rear 300/100
drilled & slotted brembo rotors
rear disc conversion w/EBC rotors&pads
steelbraided brakelines all around
17" motegi w/azenis
F&R SuspensionTechnique swaybar
Prothane bushings all around
DC strut tower bar
lower tie rod ladder bar
rear strut bar
lower strut bar
IN CAR ELECTRONICS
no head unit
4- 61/2 poineers
2- audiobahn aw1051t(10")
1- audiobahn a2002t(amp)
custom trunk enclosure
Tha bad
some stubid idiot tried to break into my car at the shop so the drivers side lock is messed up and dosent close right(i'm gonna try and fix it)
right side door has a small seal leak (it might be the rain gaurd hose)
The rear panel in the back has fadded cuz of being in the sun(upholster paint and/or dye will fix that)
http://www.youtube.com/watch?v=Y5q9TqiRL4w
http://i34.photobucket.com/albums/d1...7/DSCN3038.jpg
http://i34.photobucket.com/albums/d1...7/DSCN3037.jpg
http://i34.photobucket.com/albums/d1...7/DSCN3039.jpg
http://i34.photobucket.com/albums/d1...7/DSCN3041.jpg
http://i34.photobucket.com/albums/d1...7/DSCN3040.jpg
