windshield wiper problems
ok this is how it goes i was at my friends garage jus parked with my car on right well then all of a sudden my windshield wipers jus go off and the switch isnt even turned on and now the only way to stop them is if i take of the wiper washer fuse on bottom so if anyone knows anything about this could u help
Re: windshield wiper problems
http://www.google.com/products?hl=en...num=1&ct=title
Could be something to do with the Multi function switch.
Check the ground block behind drives headlight,it could be a bad connection.I had this happen to me my wipers would go on when i turned on my lights,drove me crazy til i found it.
so is that the ground that goes from the valve cover to the fram or is it somewhere i havent seen before?
There are I think 6 ground wires connected together,there is aplastic cover over them right next to the washer bottle.
ok i found them but once i get to them wat should i do and also is it normal that the plug has like slim in it or goo i dont know wat it is
also wat i noticed was that in the morning when i started the car the wipers didnt go off but when i started the car after school they did it again
