The title says it all, I had my sunroof tray fill up and over flow onto my headliner and now it sags in the rear pass. Any Ideas on how to fix it or just get it replaced (Possible Mold).
is it the cloth or vinal kind? if its the cloth you mind as well just throw it out if its vinal go ahead and pull it down and check for mildew i know mine had allot of of mildew from a leaky sunroof and stunk hella bad
Well.. My "door carpeting?" was fuxxed, and I got bored one day. Maybe this could help? All you gotta do, is go get a can of spray adhesive, a cylindrical object (a soup can for all i care, or a paint roller, preferrably with no paint on it :) ) and a flat thin object (can be a hand-roller, as pictured, or your big toe-nail.. I don't care too much).. pick the best starting point, which would be the spot on the edge of the headliner closest to the sag. Get that flat object and pry the fabric out of the plastic stuff that holds it in. (im runnin' on 3 hours here.. bare with me).. Pull the fabric back to the sag, spray the adhesive liberally, let sit for a minute or two to settle, flatten against the roof starting from the point it isn't sagging from and rolling flat the whole way. I know my instructions are fuxxed up, but you get the picture. Here's what I did.. down there.. look down. NAO!
http://img30.imageshack.us/img30/743...iktyurs012.jpghttp://img30.imageshack.us/img30/car...jpg/1/w640.png
http://img256.imageshack.us/img256/1...iktyurs046.jpghttp://img256.imageshack.us/img256/c...jpg/1/w480.png
http://img35.imageshack.us/img35/169...iktyurs063.jpghttp://img35.imageshack.us/img35/car...jpg/1/w480.png
Hope this helps bud. Good luck :werd:
these headliners are cardboard underneath whether vinal or cloth, it's molded so you can't just put a flat piece in. if it's bad the only fix is another headliner, or very carefully peel that one apart, duct tape it back together on the back side if needed,then glass over it. it only takes a layer or two of fiberglass cloth, it should still be flexible to put it in. I figure they are hard to find there so you may have to fix it. also the spray adhesive in the can will not hold up a headliner for long, you have to use some pro type contact cement. i've tried the super 77 overhead and it just doesn't work.
its Cloth, I dont want to fix it until I can get the rear drain lines blown out.
the sun roof is hella easy to fix man drop the head liner and you see 2 clear lines runing down each side of the roof unplug them from the sun roof and blow them out i just used my mouth and it cleared them up for good!
I'd say just go to the junkyard and find a new headliner. They're easy to pull out and easy to put back. I have a vinyl liner and spent some time filling the dings before I put the new one in. Hardest part was fitting the new headliner into the 3g and driving home with it resting on my head. No sweat bro.
Around here there are plenty of places that will restore headliners for about $100. When I lived in Corpus Christi it was $50.
Sometimes you just have to spend a few bucks and let people with experience do the work. It's not an indictment of your mechanic skills.
I paid for reupholstering the seats on my first car - a 72 Catalina. It was worth every penny.
it's not that hard to fix the headliner, for something this old most shops will also repair it. duct tape to piece it all back together and fiberglass will fix it just like new,then recover it. thats the same method most shops use i need to find my pictures of doing mine.
here you go,this is what the headliner looks like without material on it, you can't see the 500 pieces of tape piecing it back together before it got glassed up. fell apart like old paper.
http://i220.photobucket.com/albums/d...ile/IMG018.jpghttp://i220.photobucket.com/albums/d...ile/IMG016.jpghttp://i220.photobucket.com/albums/d...e/IMG017-1.jpg
and after
http://i220.photobucket.com/albums/d...e/IMG021-1.jpghttp://i220.photobucket.com/albums/d...e/IMG020-1.jpghttp://i220.photobucket.com/albums/d...ile/IMG019.jpg
