Re: SMOG tips on passing...
Well you've definitely done your homework. Maybe you should be telling us how to pass smog. LOL. As a rule, you want to set the car to the factory settings to pass smog. You'd probably get better results by having a fresh tune up and oil change than by tinkering with timing. I would avoid Seafoam myself. It's good to have the combustion system clean, but I'm just not sold on using something real caustic and disruptive on an old car to achieve that. I'd sooner use a gentler compound over a longer period of time. This is just my opinion and others on here will say that Seafoam is the cat's pajamas so you'll have to make your own decision. The alcohol trick definitely sounds plausible but it could also lean out your mixture and put you over on Nox too.
More to the point, why are you so concerned about this? Is the car not running right? If so, you're best served by getting it running right and let the smog check take care of itself.
