No power to headlights???
For those of you that don't know my 86 hatch rear-ended someone and sat for 8 years before I got my hands on it. I've been working on it since late august and started driving it a few weeks ago.
Everything works except for the headlights and front blinkers. I do not have a decent manual for the car yet so it's been a frustrating thing to diagnose. I've checked the underhood and under-dash fuses and none of fuses are bad. I've found 3 relays... the black one on the back of the under-dash fuse box, the silver one in the underhood fuse box and the identical silver one behind the LF headlight. I do not know if these are bad or not.
I should note that I had to remove the original headlights altogether because of the heavy crash damage. The damage, and subsequent weathering sitting in a dirt lot, caused some wiring damage as well. I found 2 big nodes of grounds behind each headlight attached to each inner fender. I had to clean up the passenger side but the drivers side is fine. I attached new ground straps to the transmission and the valve cover and repaired some other miscellaneous grounds.
Despite all this I have NO POWER to the headlights or blinkers. Is there a circuit-breaker somewhere I'm missing??? If I don't get any suggestions I guess I'm just gonna have to wire in a new circuit for the lights.
Any suggestions appreciated :D
Re: No power to headlights???
I can give you the manual, but that's about it. Maybe it's enough though.
scars_of_carma
did you check the fusible links in the underhood fuse box? there is one big link that splits into four circuits, each headlight has it's own fuse. also check the big multi pin connectors under the dash and see if they are loose, there are three of them right next to each other.
I can give you
Thanks! ...I've been looking for that :)
lostforawhile
Err... the fuses under the dash are fine. Where is this fusible link in the underhood fuse box exactly? I see the 4 large copper links with the fuses in em but those appear to be fine. I even removed them to be absolutely sure. *shrugs*
Seriously where is this fusible link??? lol
scars_of_carma
sounds like you already checked them, do either your low or high beams work? what about your parking lights?
I'd test out the combo switch. I wouldn't be surprised if it's not working as it should or if it's gotten unplugged at some point. I had one nearly catch fire on my because there was so much crud between the contacts. Cleaned it up and lubed with the proper grease and it was fine for about a year, until I parked that car. I think I sold that combo switch and someone on here is still running it.
lostforawhile
Neither low or high-beams work. Parking lights work.
Vanilla Sky
Already tried that I replaced that whole unit cause my wiper stalk was broken but no change to the headlights.
Do the headlights come up when you turn them on?
Vanilla Sky
Heh, no they don't because I no longer have functional pop-up lights. My car rear-ended someone and everything behind the bumper was crushed including the electric motors for the lights. I had to cut everything out with my grinder.
I have new (used) headlight assemblies rigged up but I couldn't mount the little motors where they used to be so I didn't try. I suppose I will have to raise and lower the headlights manually :rolleyes:
I'd test the connectors for power to see if they would be getting power.
u check the contacs on the bulbs for corsion? they could just be dirty thus needing cleaning
