Swaping In a B Series motor into a Carb'ed car?
I was running over the carb to efi thread and saw the fuel tank difference. My main question is if I swap over to the B-series motor would I still need to either A :swap my fuel tank. or B:modify it so it can take a different fuel pump? Sorry if this is a noob type of question or if it has been asked (But I did search first lol). Main reason I ask is I just read that innovatives now makes the mounts again so the thought popped into my head and I thought I should ask.
Thanks for all the help
Re: Swaping In a B Series motor into a Carb'ed car?
You would need EFI fuel lines/tank or you could run the B-series carbed ;)
The fuel tank is the least of your worries when doing such a swap :D
get the b series and run a weber 38/38!
carotman
haha well this is true, But the main thing I was worried about was the mounts but those are back :D. But it would suck to get everything in then not be able to get fuel lol.
Naf's Asdf
Ok so I would still need to do all that as well. Damn lol. haha just rock some itb's
you can use the A20 carbd intake manifold on it, with the weber...
Hmmmm rocking a B with a carb on it. Well that might be a Idea, but before that I need to get the Engine bar'd since it is really not that hard. gah, well maybe I'll just drop the tank and see what needs to be modified
