Re: need info on auto mount
so someone mentioned that the rubber on the end of the tranny to frame rail is just for vibration and i could get away with out it..
any one have and idea?
you dont need that mount....i had to take out my auto trans 3 time so i just left the mount off.
You can pick up a bolt on mount from the junkyard. I'd put it on myself. Honda didn't spend money machining 10 billion of them just for giggles.
its 5am and the trannys in took it for a drive everythings worked out well it took 5 1/2 quarts to be filled. dose this seem right?
shifts nicley maybe needs a little adjustment on the tvr cable..
i will say it was easey to do this job but very time consuming. we just partyed the whole time and got wasted lots of fun :)
Dr_Snooz the reason i cant use the mount is that the tranny i got simply wasnt designed for it so im guesing its a older tranny..
There aren't two bolt holes on the top of the trans near the passenger side?
no there is not. plud theres no meat there to drill tap holes as it was not in the design.
