Help please
ok i started my removal of vacuum lines on my accord i cut out the black box but it is high idling 2000 rpm idk y it only does it in park or nutral i need some help on y it would be high idling i was thinking maybe vacuum leak or the
MECHANICAL SECONDARY CONVERSION that i did is sticking im a noob at doing this is my first carb accord help me out guys thanks
Re: Help please
sounds like a vacuum leak, make sure you blocked off any hoses that lead right into the manifold or such.
Re: Help please
The mechanical secondary conversion can be dangerous so you want to make sure you don't over-tighten the throttle shaft nuts and you'll want to add a return spring to help pull the throttle shut.
Other then that if you remove the "choke opener" that will cause a vacuum leak at the front of the carb next to the screw hole that held the choke opener in place.
