What size wrench is needed to adjust tha clutch i dont have one big enough and dont want to buy a full set to get tha right size.
You should be able to turn the adjustment screw by hand.
i tried that and it aint happening to much shit in tha way to get a good grip i have huge fat kid fingers
DO NOT USE A WRENCH!
You will screw up the "PLASTIC" clutch cable adjustment nut.
There is a rubber nipple at the bottom of the that adjustment nut that you just push down with your thumb/finger and turn the adjustment nut with your hand.
You should only have about 1/4" play in the clutch arm.
i had to adjust mine too. it's a bit tight to reach, but no wrench should be needed. last resort- use pliers. that might work.:dunno:
