w261w261
If I understand your post correctly, you have a set of 4 springs (not just the front). And you want to know what to do for the back?
The answer is: put in the springs and leave everything else alone, unless you love working with small detail. A 1" drop can easily be accommodated with the existing geometry. I've run Eibach 1" drop for years, plus on my right front a pothole had banged the mount a bit, so I was -2.7 there. Still no tire wear, no handing problems. A couple of years ago I installed a camber-adjusting UCA mount, but I probably didn't need it. I can't tell the difference.
Just stick in the springs, collect the drop and move on.
