I bought a gold top b20a engine and tranny from ebay. Was going to tap on some of the guys here who have done that swap. so who are you?
b20a
fixed............thanks!
so it is a b20a
it is
Ii did. If you can swap an engine you can do the swap. Read the board at least twice to figure out what direction you want to go. You can go OBD1 swap and utilize the engine for what it is but its costly and very timely. The easiest way it to use a teg dizzy and cam pickup and use the pre obd setup. good luck but read before you ask.
its almost a direct drop in...what is your question tho?
indeed what do you want to know??
remind me i should really sort out some a20 to b20 swap page on b20a.org
i also have a B20A swap...
me two
