I finally got a little done, the battery box is bolted in, the washer tank in, and i'm finally running some harnesses permanently. it shouldn't be too long until the passenger side up to the firewall is finished. I'm using these old factory floor mats as a template to eventually have some new ones made, i'm modifying them to fit around things, and i'm going to have to add some material.
doing a little plumbing to hook the washer tank back up
http://i20.photobucket.com/albums/b2...c/S4021357.jpg
battery box in, and you can see where the radio box goes. cover is off in this picture, but it has cooling fans also.
http://i20.photobucket.com/albums/b2...c/S4021358.jpg
washer tank back in
http://i20.photobucket.com/albums/b2...c/S4021359.jpg
underside of dash, there is a piece of silicone tube that connects the blower and heater box together. you can also see the power antenna motor
http://i20.photobucket.com/albums/b2...c/S4021360.jpg
