Re: Squeeling under the hood
When did the noise start?
Maybe a week or two ago. It was just outta the blue. I was like wtf?? and its only when my engin warms up it doesnt do it when i first start it.
You should take a video. That will get you the best possible answers.
well my car had no power(not spining tires in really loose gravel. and it was rattling.. I turned it on to show my dad and it died. after school i came home and pulled off the valve cover and saw the timing belt was loose. pulled upper timing cover off to have a cam gear go with it. I was sheared completely off with the bolt still in it. Im assuming when i replace the cam it shouldnt squeel. Moral of this story. Never under estimate a little whistle from under the hood. :Owned:
O_O how the hell did that happen O.o make sure the heads not effed up (score marks where cam goes) and replace the timing belt and tensioner and water pump while your at it..
Why replace all that stuff lol i understand timing belt and tensioner why water pump though? im pretty sure its ok? Just curious
because if your water pump goes out you will have to redo the timing belt
DANGIT still squeels changing that water pump soon hopefully. >=/ These cars are lucky they have so much potential cause id get rid of it. Cause i dont have many problems so i dont want my car to be like one that does eventually.
