ecogabriel
Read the instructions in the can itself.
However, I am not sure that you can drive THAT long (or drive at all) with seafoam in your oil.
If I heard (or remember) right, you are supposed to add it to the crankcase and run the engine at idle for a few minutes, and then drain all the oil.
I used seafoam to clean my intake manifold; if you use it that way make sure to be away from your neighbors the clouds are something to behold!
By the way, is your engine so dirty to start with? Because if that is the case I'd be concerned with that crap getting loose and clogging the oil pump pickup screen and starving your engine...
