how do i take the manual window rolling handle off so i can get the door panel off. need help thanks
http://www.ricksfreeautorepairadvice...xt-279x300.jpg
you can use a knife instead of that "removal tool"
Look between the handle and the door panel, you might have to get creative but there should be a spring clip around the crank. Simply remove the clip with a scribe or needle nose pliers and pull the crank off. That simple. This is strictly from memory. I could have the wrong make and model :dunno:
ok thanks so much guys! i just used a small flat head screw driver and had no problem
take a stiff piece of wire like welding wire, bend a small hook in the end, hook it on the clip and pull. been doing that for 20 years. i have one i made with a wooden handle
and hope no one installed the clip backwards like i did a few times (Y)
and similar to lost, i have some small o ring picks that are just the thing for such jobs
Putting that thing back on was a pain in the #(@ how do you guys put it back on easy?
lol, put it on the handle and push in to place.
All you have to do is install the clip back on the handle completely. then just pop the handle back on. That's why it's tapered.
Yeah, going on is the easy part!
I use a dental pick to get the hook out to begin with.
