Re: White Cloud from hell
that sounds a lot worse then a headgasket sounds like a cracked head or block, the horrible grinding sound because of no oil probably means the engine is ruined
lostforawhile
Well that sucks. :/
oh well the car only cost me 100 bucks so it was worth it.
elbringit
Well that sucks. :/
keep watching on here and you can probably find a decent engine, if it was just a headgasket I would say fix it, but the clouds of smoke, oil out the exhaust, and grinding from lack of oil makes it sound terminal, is the rest of the car in good shape? if it is a used engine dropped in might give you a good car. it sounds almost like the cylinder walls were destroyed from lack of oil, and the oil is just blowing out the exhaust, the smoke around the manifold may mean a cracked block.
lostforawhile
Not really interested in messing with it. Tranny has 350k mi and the body is rough. No hood no back glass trunk randomly pops. No ac aint worth it to me
elbringit
you might be able to sell some parts on here, make your 100 bucks back
Hell, he could sell the car as-is for $100.
lostforawhile
Posted it in the for sale as a part out not sure if thats the right spot though.
Pissed off too cause I was just starting to enjoy it :/
Just spend some money on a cheap compression tester to verify you head gasket is blown. :D
88Accord-DX
it sounds a lot worse, he stopped it because of a grinding sound from the engine, and it didn't have any oil in it, after he added the oil it turned into a mosquito fogger
lostforawhile
I agreee with reading the post again. It sounds like his motor is pretty much toast w/ low oil & grinding.
