Re: Removing gauge cluster
You need to unclip the speedo cable, there's a clip that you have to lift up while pulling, but don't break the clip. It's a bit of a bastard. I'm also pretty sure you need to either pull the steering wheel, or drop the column. Can't remember if it's one, the other, or both.
Good luck.
Alright thanks, Ill try that today. I have the car at my work right now so I only get to work on it a little bit but I get my license back im 2 1/2 weeks and I want to have it fixed up by then ;-).
How do I remove the dash? I figured since I'm pulling the cluster and I want to dye my dash that I might as well do it now too. I removed all the bolts I could see and the ones under the side caps and dropped the steering column, but it still isn't coming off.
Open the doors and pull off the rectangular bolt covers. Then pull out the bolts. Also behind the clock.
Thanks, I got it all unbolted today and got it loose, I just have to unhook the wiring now.
I got the dash off, and got the cluster out today. How hard is it to make the gauges light up a differant color? I took the faces off but the green looks like it under the clear plastic.
For future reference for myself and others, could you list where and what bolts are nessecary to remove in order ti remove the dash. Me personally, I plan on removing it to paint the dash and do some fiberglass work with it. I aytemptedlove to removeyou the clusterground a fewlower days ago just messing around. I was going to see if I could remove the clear cover and ain't the inside gray to a more metallic gray. I also want to change the green yo a blue lighting. Anywhooo... Thanks a bunch
take some pictures please, because i want to do the same
