I'd be happy with rich or lean. It doesn't do either. Unless it does both. Sometimes it's blank and others blinking too rich, or too lean, or just right, under the exact same conditions. Sometimes the lights flash sporadically around a level and other times they are stone solid. Good grief. I still say you can do better by deepening your understanding of how carbs control the mixture under various conditions (jets, metering rods, stepup springs, floats, accelerator pumps, etc.) and learning what lean misfire feels like. Once you have that all figured out, you just lean each control out until it misfires and then back off until it stops. If it stinks like raw fuel, it's too rich. The A/F gauge did help to sort of confirm what my nose told me, but it was so variable in its readings that I ultimately just went with my nose.
