i know we've been over this before but...
OK, Jim, I need you to spell it out for me once again.
I know that i can send Billsteins back to the company to get revalved for a harder rebound setting. That's kool, but I don't have Billsteins.
But I've also heard that Koni offers the same thing too. Is that true? (Yeah, can you tell I have the Koni's?)
Now another thing that got my attention was the mention of the fact that I can get the Koni's shortened too. That's some real good news for the autocrossing enthusiast that I am. How do I go about doing that too?
Now maybe this should be in another thread, but as you may remember, I'm the dope that wanted to be diff. then all the rest and get the ever covetted B&G's. And once installed, instead of the claimed 1.6" drop, it was more like 2.6+". So now I'm thinking that I do LOVE the stiffness of that spring, and want to know if there is anything with a comparable, or even harder, spring rate then those without having to move up to the G.C.'s.
Re: i know we've been over this before but...
BTW the revalve I did on the Bilsteins took them from being 15% stiffer than stock (Bilsteins words) to being 190% stiffer than stock. And that was for rebond and compression. I wanted them to be able to handle up to a 400lbs spring rate.
Yes you can get the Koni's revalved and shortened. Here's a cut and paste from when I did the reaseach on this a few months ago.
"On your Koni's. I talked to gordon at Koni and he said that it cost's $100 per strut to revalve plus parts. He said that the parts should not add up to much. He confirmed that you can revalve them based on what spring rates your using. Plus if at the time your having the revalve done you want them to convert them to EXTERNAL adjustment, it would only cost you $25 per strut. And I asked me if a revalve is the same as a rebuild and he said no, extra parts would be involved, but he said it would cost much less since the strut would be torn down anyways. And one more thing that may interest you, for $65 per strut, they can shorten the body and piston. Which I would highly recommend with you running them so low."
And on the question about if their's any other spring you can get that is stiffer than the B&G's you have other than going with GC. The answer is yes, but you may not like it. Drop zone coilovers are. But they are so stiff that their's no way that I could recommend running them with stock koni's, you'd really have to revalve them stiffer. Your B&G's are 350lbs front and 240lbs rear
The drop zone coilovers are 450front and 350rear. Otherwise I went over my spring rate chart and their aren't any springs that are stiffer than the B&G's, they are all really close cept for the sportlines with thier wildly low rear spring rates and the H&R's/Neuspeeds, which are much softer. Even the Ground-Controls would have to be custom set up to be different, stock they are about the same as the B&G's. But since they are NOT a progressive spring, the GC's would have a different feel just for that fact. It's the difference between linear springs and progressive springs.
