Engine Smoking/Smelling Oil
Has anybody had an engine smoking problem. I got seals replaced and i see no evidence of oil leaking on ground anymore but every time I drive, when i park or am idling after about 15 mins i see smoke coming from under hood and smell oil. The car runs great but cant understand why its still smoking. Any suggestions or thoughts .... PLEASE HELP ???
Re: Engine Smoking/Smelling Oil
Did you replace the dizzy o-ring and oil filter base gasket? They both are over the exhaust causing smoke.
replaced the cam seal gasket, value cover gasket, timing cover gasket, oil pump, and water pump .... those repairs where done 3 weeks ago
I would say that you need to replace those two seals. If they have never been replaced then chances are that they are hard as a rock and not sealing like they are meant to. I am replaceing mine tomorrow and you wouldnt believe the trouble to get the gasket off. They were junk causing my car to do the same as you are discribing.
Majestic Honda Auto
Oil filter gasket = $3.00
Distributer O-ring = $1.75
I've had that problem before. I had new valve gasket but not a properly sealed valve cover. Then months later had to replace oil pan gasket because my car was smoking like a dragon
91lowrider
Majestic Honda Auto
Are these gaskets that cause you to have to take down the car like major work or are they pretty easy to get to ?
common problem for the dizzy o ring to go out. also the oil filter base. pretty cheap to fix
thanks everybody .... will be fixing that ASAP 3GEEZ.com is BALLIN :bowrofl:
SladeHonda
They are a easy fix. You could have it all done in less than a hour. You need a 10mm socket for the dizzy bolts to replace the o-ring. Then for the base gasket you need a 24mm socket to remove the oil pressure switch and then a 10mm socket for the 3 bolts holding the base.
Oil filter base is a likely candidate for smoke; if it leaks it may do so on top of the hot exhaust pipe.
x2 on the advice about seal replacement. If you see oil on top of your transmission under the distributor, then either the o-ring or the shaft seal inside may be leaking. I had to replace the distributor shaft seal too; I did a posting on how to do it when I replaced the distributor bearing (another non-standard sized piece... thanks Honda!).
Man AutoZone nor Advance Auto Parts carries the gaskets. Where do you find these parts at ?
SladeHonda
Here is the base mount on my 88 LXi. https://www.3geez.com/forum/showthread.php?t=73427
If not from the dealership, online
http://www.hondiscountparts.com/HO_O...asket_list.htm
Try NAPA; they may carry parts that others do not
Base gasket and Distributor o-ring are dealer or online Honda dealer parts like Majestic. I matched my distributor o-ring to metrics I had. But base mount is a dealer item and may as well get the distributor o-ring from the dealer order while you are at it.
Ok not sure whats wrong with that website but after i click on something just get a white screen but ill try it on another computer once i get off work
Majestic has both seals you need cheap but your going to be paying for it with shipping. It took a week to get the stuff i ordered so expect to wait a week
91lowrider
I found the distributor gasket but what would the oil filter base gasket be under cant seem to find that one
SladeHonda
It will be under breather tube-oil filter on the dealer sites. Here is BK but it will be under the same title on Majestic.http://www.bkhondaparts.com/find-par...20OIL%20FILTER
Bluntman
Ok so will u check to make sure im buying the right parts the oil filter base gasket is $2.52 and the distributor O-ring is $1.39
I have also noticed some oil is collecting right under the headers down low in the front of the engine. Any ideas where this could be coming from ????
SladeHonda
sounds like your oil pan
