Re: Belt skweeks on startup
I would rough up the alternator pulley with some sand paper so the belt grips it a little better, try that.
When I had that noise in my car, I tried adjusting the alternator's tensioner over and over again, and I first screwed up the water pump than getting rid of the skweeking noise.
The remedy was to put a new belt.
Buzo
x2.
If you keep on increasing tension eventually the water pump bearings or the alternator ones may give in. Getting a new belt solved my squeaky noise.
Unless the other two have been changed recently, replace them all.
