Lowering spring stiffness % over stock spring stiffness
I was helping a member understand something about a certain spring by showing it's spring rates vs stock spring rates by showing it's percentage of increase over stock. I went ahead and did it for all the one's I have rates for. I did not do the eibach prokit or the sprints since the rate info I have is not the same rating system as the other's. I will call eibach and ask how I may figure out a way to rate them equally to the others, (I'll use that system for the sprints as well).
Notice the front to rear rate differences. Increasing the rear rate more than the front will reduce understeer. Increase the front MORE than the rear and you will have more understeer. Also take note of how much more spring power you'll be asking your struts to control
Brand front&rear %+ over stock
Tokico 1" front 66% rear 63%
Susp Tech 1" front 62% rear 54%
Eibach sp lines front 62% rear -32% (low figure double verified)
Eibach prokits front 44% rear -17%
*See note below on eibach spring rates
Neuspeed&
H&R 1.5" front 26% rear 41% (softest lowering spring ava.)
Progress 2" group front 70% rear 205%
B&G 1.6" front 66% rear 205%
Suspen techniques
speed tech 2" front 73% rear 196%
sprint
2.25" front 66% rear 192%
Ground-Control front 61% rear 214%
Dropzone coilovers front 213% rear 300%
Spring tech coilovers front 213% rear 300%
*After talking to eibach to find out how to rate the prokit's they said that the first spring rate they gave me should be equal to how the other spring makers gave out their spring rates. So, the prokits are front 308lbs to 742lbs rear 97lbs to 200lbs. The first numbers are with the car's weight resting on the springs. The second number when the spring is fully compressed. It should be noted that with the sportlines the absolute max stiffness their rear springs can do is only 21% stiffer than stock and that's when the spring is full compressed. Most aftermarket rear springs start off being stiffer without being compressed at all.
Re: Lowering spring stiffness % over stock spring stiffness
So that would make H&R, Neuspeed, B&G and all coilovers more desirable for handling - correct?
With the H&Rs & Neuspeeds being the softest - does that mean that they would not be good for strong cornering?
Thanks, Jim, for always being willing to share what you know!
