type r calipers + mini cooper/lengend rotors
So ive been wanting to do this brake upgrade. seem the legend rotors are the way to go. are the cooper rotors the same. ive went to rock auto and the numbers dont match as size. but yet the integras run em.
legend rotors specs
Outside Diameter: 11.09"
Overall Height: 2.01"
Number of Bolts/Holes: 4
Bolt Circle: 4.5
Discard Thickness: 0.748"
Vented or Solid: Vented
Mounting Type: K
Mini cooper rotors
Outside Diameter: 11.015
Overall Height: 1.74
Bolt Circle: 3.937
Discard Thickness: .803
Mounting Type: K
as you can see numbers are similar but not. has anyone tryed em?
Re: type r calipers + mini cooper/lengend rotors
Check this thread:
http://honda-tech.com/showthread.php?t=3044628
Apparently the diameter is just a hair too small and the pads hang over the edge a bit.
C|
dont make it hard and stick with what works....89 legend rotors, ITR calipers and pads. i been running these set on 2 3gees. on the white coupe i upgraded and also on my 3gee that i already put 18K since. no problems just wished i had better suspension and tires
Have to get 88 knuckles . I found a dx but has to be a lxi damit
understood LOL. went to fast brakes and DAAAAMn 500 plus for the convo you has to be joking Lol. So i can get full loaded calipers cheap (oem acura) and im in the process of getting the knuckles.
SO where in fast brakes are the rotors i can just buy. I did not see any lengend rotors in the menu
so the 88-89 knuckles will work with the ITR calipers and pads and legend rotors all bolt on?
Rendon LX-i
I think its on my link but hes got them on there maybe under civic conversions.
http://www.fastbrakes.com/product_p/...h%20rotors.htm
I think this is it.
there is a listing for rotors wit hub centric rings not sure what there apps for.
EDIT: also I never have tried doing it myself but you could buy the regular Teg R rotors and try drilling the 4x100 pattern your self. The last set I got from Brian one rotor the hole was off a little and need some filing to fit.
gp02a0083
Except you have to get thd Legend rotors re-drills.
read here
cygnus x-1
yeah that's the chart that got me thinking about 11.8" rotors that can fit under a 15" wheel.
One questions: For the ITR set up, would you need the ITR caliper and bracket or just the caliper?
obdriver6
You will need the brackets as well.
Legend_master
Thanks cause I can get a good deal on ITR calipers w/ brackets where I work at. Also, sorry for thread jacking rendon.
